Hi guys...
Just after a straite yes/no answer, been doing some research and cant find what i need...
I have a R34GTT and im looking at buying a s/hand Excedy twin plate clutch from a R33 GTR. It is a pull type clutch, comes with replacement flywheel only
Will this bolt straite in and work or will i need a push pull convertor? Are the clutches the same size?
Any info you guys can give me would be great
Thanx
https://www.sau.com.au/forums/topic/397535-r34-gtt-twin-plate-upgrade-help/
AT the moment the car is running stock turbo, the plans of a bigger turbo are on the cards for the near future though, so im planning ahead...
The clutch is cheap!! Under $500 thats why im looking at it
The R34 pull type clutch uses a 250mm plate so straight off the bat they are gonna hold more torque than the 240mm plate on the previous models. Unless you are going to be making more than 550hp at the wheels then you can get a really good brand new single plate from NPC for about the $900 mark or less and if you aren't going to go over 400hp at the wheels, an organic plate behind a slightly modified cover will suit you fine and they are $100 cheaper.
Is it worth buying the second hand stuff to suit a different model and possibly having issues just to save a couple of hundred?
It certainly won't save you any money if there is problems and you have to pay twice to have it fitted or fixed
Twin plate clutch on a std gtt, do it like everyone else does upgrade power and handling and wait for shit to break.
Upgrading the clutch first with a possible stuffed used twin plate is stupid.
I hear what your saying and thanks for your words of wisdom. The twin plate excedy to buy for my car is over $2k so if i can buy a s/hand one from a a different model for a quarter the price then i would be crazy not to give it a go if it was to work the same..
Im trying to find out as much as i can re: fittment to try work out if i have to mod anything to make it work and then i can see if its going to be cost efficient.
power wise i doubt the car wil see 500hp@wheels. plans are for a 35R on E85 around 20-25pound with some drop in sticks
Im not going to buy the clutch if its stuffed am I!!!
GT35R on 25 pound of boost and E85 is going to see 500 hp.
On the subject of buying a stuffed clutch - do you know what you are looking at? How are you going to tell if the plates are worn out or if they have X life left?
Then even if you know that, are you going to be able to tell if there is spline damage, a warped hub or a fragmenting friction material?
Just because something is is $2000 new and you can get it for $500, doesn't mean it's going to work well and the fact that it's 1/4 of the price would usually tell me that it needs rebuilding.....which is going to set you back about $800-900 anyway.
Exactly.
come back and ask the question again once youve done all of this ^^^^
cause you make it sound so easy... if your skimping on a new clutch but have these plans to a 35r you either dont know what your talking about or it will never happen anyways...
leave the 'twin plate' clutch till last, get a clutch that will handle stock power for now if your current once is dead...
you do realise for under 500hp you dont actually need a twin plate necessarily...
do some more research
Damm this has turned into a HATE fest!!
Excedy web site shows same part number for both applications, so that tells me it will work. Advise given re: it might need a rebuild... isn't that the risk we all take on buying second hand parts ???
I am also aware that a single will probly do the job, well it will do the job but i would rather just go hard on the clutch while im there, better to go over kill now then have to replace it again in 12 months when the car is making power as FYA would do!!
If i have to rebuild the clutch it will be as good as a brand new unit and still cheaper then buying brand new unit in the first place
Not a hate fest at all...
just dont understand, if your aiming to do things right the first time why but a used gtr clutch, why not get a decent new clutch to suit your car...?
after the conversion to make it fit and then the possible rebuild, you would of been better buying the right clutch first time round...
plus the fact the twin plate will suck with everything else std...
your simply doing it wrong...
FYA i think u need to read my post again....
The clutch is the right clutch for my car. There will be no conversion! Its the same part number so that means its the right part for the job.
The car has everything else done, just still running stock turbo. Will the setup i have now its making 270@wheels so I think the twin plate will be fine. It has a sprung centre so drivabilty for my weeker should be perfect.
Thanks all for your input
Question: Can I bolt an R33 GTR clutch to my R34 GTT RB25DET Neo and will it work?
Answer: Yes
Secondary answer: They are not the same. Even though Exedy may now sell them under the same part number, they have different release properties due to cylinder differences and the fact the GTR has a clutch booster, so you may get a shit pedal feel. Most people adjust it out but there is a tradeoff..
I will make a 50c bet that says the $500 pull type twin plate makes a better boat anchor than it does a clutch that will serve you well. Rebuild it - IF it's possible to and the damage is not too severe AND you have just outlayed $1300-$1400 when you could have just bought a proper single to do the job that will feel nicer, drive better and will be BRAND NEW for half the price.
I understand where you are coming from though, but out of every customer that walks in my door and presents me with a second hand part to fit, they have ended up needing to pay more than what it would have cost to do it properly the first time.
If you still want to get the secondhand twin plate, let me know coz I have a few old rear main seals and an alright looking spigot bush laying around somewhere.
  • 3 weeks later...
Hey R33L,
I can relate very muchly to overenginnering everything you put into the car.
The confidence whilst driving that the machine is strong and nothing you are going to do will hurt it; makes me very happy.
I achieved this just by putting in an exedy heavy duty and the flywheel that went with it... It feels stronger than anything else in the car.
Then again i'm not making 270 :(
But if this part has come out of a 33gtr it could be more than a decade old... And You've
got more issues to worry about upcoming than just the clutch too.
By the time you've done 130,000 like My car has you'll have your synchros in the gearbox starting to wear out too. Mines having a recondition now.
Pain in the arse.
I have HKS GD max Twin Plate clutch and lightweight Flywheel for sale its only done max 500klm max to suit r34 GTT might suit others as well 32,33,34 GTRs,
took it out as I personally didn’t like it, it has that stock feeling very light but bitiey as hell .went back to single plate .
I have paid $2700 + shipping for this HKS twin plate clutch brand new
Will sell it for
$1300 firm
just to cover costs of my single plate ,
please let me know If your Interested PM me and I can send u some photos and measurements of how thick the discs are.
Fark no, please dont use a secondhand clutch plate, the bastard could have been tortured to the shithouse and caused damage that wouldnt be obvious till you have had it fitted to your car
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
    • I presume it would take more than just slapping a big modern catalyst on the exhaust? It's interesting though, looking at the old sales brochures and listings it does not mention anything about emissions. No one cared.
    • Yeh nice, looks like their part of keep it reet? Will have to swing past. I'd much prefer someone actually look at my car and custom make a part, then get a generic part online and hope it works.
