Hi all, im in the process of building an R32 drifter i want around 400-450hp, its currently got RB25 i put in.
MODS
Microtech LT12s
FMIC
3inch exhaust
YellowJacket coil packs
Stock everything else
its making 200kw on 12psi
My plan is the folowing mods
hypergear xIU stock 25 turbo highflow
WMI
Will this come close to that power figure or will i be better off buying a GTX 30/76?
Edited by 51NNA
https://www.sau.com.au/forums/topic/397558-400-450hp-rb25-build-questions/
  • Replies 42
Well you will need bigger injectors, Fuel pump, a little highflow wont make 450hp at the wheels
GTX3076 will be over kill, better off with a GT3076 or if you really want a silly billet wheel then a GTX3071 would be better suited
Assuming you mean 400-450HP at the engine, then yeah, the Hypergear highflow will get you up into that space. But you're likely to need more fuel. I wouldn't rely on the meth in the WMI to provide enough. You're also likely to need to make sure the ignition system will cope.
It does have yellowjacket coil packs, i was hopeing for RWHP and Zebra i wasnt 100% sure on spending the extra 500$ for a billet wheel, but would you go a 71 over a 76? and my injectors are only on 50%duty cycle so hopefully they would cope too atleast 370-400hp with the WMI
Are they standard injectors? If so they will not do 400rwhp, about 300rwhp is the limit at standard rail pressures
WMI should not be used to increase fueling capacity, doesnt work like that
GTX3076 is capable of 500+rwhp on the right fuel nad engine, but slightly laggier than the regular GT3076 which will do just shy of 500rwhp on the right fuel/engine
Well i was hoping too be sneaky and run my AFR at 13 with the wmi protecting against ping, ATM its 199.6rwkw with 53% duty cycle with stock injectors on 12:1 afr
Edited by 51NNA
Its pretty interesting to find that Toshi managed 2x 260rwkws R33 using our stock 21U R33 high flowed turbos on factory injectors pump 98 done on two different dynos. Not sure whats the go there, unless he can flash the stock ECU to run stock injectors at 100% injection or some thing similar.
only with toshi's remaps.
2 results out of hundreds of others doesnt make it a trend imo
Only with toshi's remaps. I remember he stated some where that he can make it do that no worries. I've never seen that done with other tuners.
Well looks like im up for some injectors too lol, 550cc be enough?
OR buy a GT30/76 or GT30/71, WMI and put it back on the dyno and see what happens and go from there, after all spending 1k on injectors i might not need (probly will do) but would be interesting too see what happens?
Edited by 51NNA
most would say 75% injector duty would be the max they would want for safety...
get siemens injectors and a new rail and it will be cheaper than sard or nismo injectors and you can get larger to support E85 and not worry about WMI....
I made 260kw at 15psi so never 100% injector duty.
Injector duty is around 88-92%.(depends on AFR)
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
