  • Replies 42
I made 260kw at 15psi so never 100% injector duty.
Injector duty is around 88-92%.(depends on AFR)
Does someone want to explain to me how thats possible?
Im making 290rwkw with 500cc and it 77% duty...
going by the above statement I could run E85 on my 500cc injectors and get more power... wtf...
PLEASE don't! :P
please do!
it's not possible under normal circumstances. unless your running wmi or something similar anything more than ~200rwkw on standard injectors is either running lean or is just a happy dyno.
please do!
Happy by 60 rwkw?
Standard injectors are 370cc, which i've been told makes them good for 370 crank HP at 100% duty and standard pressure, or there abouts? So in theory, the 400-450 crank HP Toshi is making would need %15-%25 more pressure to keep them below %90 duty?
Is that right, or am I missing something? Also interested in this.
Defently not the dyno, it reads within 3kw of factory spec on new cars that have been run up, maybe ive just got a freak 25? oh btw my vvt isnt connected =/ but that only affects mid =)
Edited by 51NNA
correct its also a dyno dynamics, my tune was done at 11pm on a winters night so it was getting nice freezing air, doubt it would make the same power in summer.
Edited by 51NNA
no...were did you get that idea from? LOL there is a setting that shows flywheel power but its defently RWKW, i dont understand why you think its so hard for a rb25 too make 200rwkw, my rb20 stock on 1bar was making 180RWKW...
Edited by 51NNA
Youll find most will say HP and RWHP these days, the tests were done on stock WRX's, when i worked there we mainly did wrx's because of the AWD dyno..and most of the time people would complain our dyno showed a low reading compared too others.
Edited by 51NNA
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
