Wrecking R33 Gts-T Skyline In Sydney
Hey guys, I have a white series 2 R33 Skyline for wrecking here in Sydney, info below
I also have a few other spares lying around, listed here:
Set of 18" Konig Privat wheels and tyres. Wheels are in good condition and include all the centre caps. tyres are worn or have camber wear
fronts are 18x8 +35 offset, rears are 18x9 +40, 5x114.3 stud pattern - $600 ono for the set
3" catback exhaust with Jasma stamped rear muffler - $250, pickup only!
Stock rb25 turbocharger with approx 100,000km. Good clean condition, minimal shaft play - $200
R33 front strut brace - $60
post-35556-0-85791800-1334210217_thumb.jpg post-35556-0-86612100-1334210536_thumb.jpg
Onto the car:
It's a white series 2 auto R33 Skyline with approx 142,000km. It's been written off due to a crash at the rear so it's all up for grabs. 100% stock car
Located in Sydney for pickup or I can post any part anywhere in Oz. PM me if you're keen on anything! Further pics available on request
post-35556-0-93353700-1334210598_thumb.jpg post-35556-0-41496600-1334210641_thumb.jpg post-35556-0-53264800-1334210666_thumb.jpg post-35556-0-65350600-1334210549_thumb.jpg
Exterior Stuff:
Series 2 front headlights, good condition. The drivers side headlight has had some cracked mounts but they've been fixed up at some point. It attaches up to the car just fine - $400/pair
Series 2 bonnet - $200
Series 2 grille - $60
Series 2 reo bar (uncut) - $150
Front guards - $75 each
front bare nose cut / radiator support - $150
Front bumper is SOLD
rear left tail light - $40
rear 'Skyline' garnish - $40
side mirrors - $40 each
stock R33 wheels with good/roadworthy tyres - $200
stock sideskirts - $120
Engine bay stuff:
Rb25det engine with approx 142,000ks. Good running condition. Did a compression test on it today and it was all good - all cylinders between 145-150psi
$1000 for the bare engine (no turbo, coils, injectors) or $1400 complete (but with no pumps/alt)
complete factory / standard exhaust & stock cat. perfect for clearing defects - $150
Radiator - $80
Aircon condenser - $150
S2 Rb25det engine loom - $150
S2 pink sticker AFM - $90
R33 aircon compressor - $90
R33 power steering pump - $100
R33 alternator - $90
Engine Mounts - $80/pair
Fuse box lid - $20
Radiator overflow bottle - $20
BM44 ABS brake master cylinder - $60
standard sidemount cooler & piping - $80
standard airbox + snorkel & filter - $120
Brakes/driveline:
Auto gearbox, approx 142,000km. Good condition, shifted smoothly. - $250
Front calipers - $275
Rear calipers - $140
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Castor rods with urethane bushes - $80
Front lower control arms - $70 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $50 each
Rear 5 stud hubs - $150 pair
Handbrake drum assembly incl cables - $150 pair
Auto (4.3) diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Full set of standard suspension - $180
Inside:
Drivers side window switch (s1.5/S2) - $60
Drivers side window motor - $100
Passenger side window motor - $50
Complete set of door trims (x4 pieces) - $100
Auto dash instrument cluster, approx 142,000km. everything works on it - $60
S2 steering wheel, some light wear around the top - $150
Instrument cluster surround (s2) with all switches/vents - $80
Auto gear selector surround (s2) - $40
Centre console - $50
Climate control unit - $30
S2 Front seats, some usual wear on the right edge of the drivers side seat - $100/pair
Seatbelts (full set) - $80
Complete set of boot interior pieces - $80 - pickup only
Ignition barrel + door barrels & key - $80
  • Replies 42
Hi do you have the passenger window switch as well as the drivers. Also I need the boot lock and catch. What price for these posted to Darwin. Was the RHS hub assembly damaged in the accident and what would this cost to send as well. I will be in Sydney next week (Kincumber) not sure where this is compared to you but may be an option.
 Share
    • Like @Dose Pipe Sutututu mentioned, 10W30 on a built motor would not be a great idea. As for the steel wool, we think alike as I went ahead and put SS wool into my catch can as per my above posts.
    • I am going to chime in here and say that is very bad advice for a built motor, making decent power of 400kW+ Especially if the rings have been gapped on the looser side. The more power you make the heavier you need your oil to be to be able to maintain that suspension between the moving parts, if not you'll have journals and bearings making love and grenade a motor. Remember that all moving parts inside the motor aren't ball bearing and are journal bearings and require oil to separate the surfaces from contacting.
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
