Hey people,
I'm doing a turbo upgrade on my R34 GT-T, and before i have put new turbo and stuff on, my mate installed a bosch 044 fuel pump yesterday.
Now as i have never done this before i'm not sure what to expect.
So symptoms that have occurred since the installation ;
i) On the highway in 4th and 5th gear, if i put my foot down there is a delay of about half a second before the car will accelerate.
ii) Even after "priming" the fuel pump (switching to 'on' so the fuel pump builds pressure), it still takes a bit to get started (turns over for a bit then sickly comes to life)
iii) This morning i "primed" it, waited for the fuel pump to stop pumping, then turned over the engine, it kept turning over but wouldn't start, so i tried again straight after and this time, once again, it came to life, but very sickly, it ran rough, felt like a cylinder wasn't firing. i then let it idle at around 2000rpm, and all went back to normal after a few seconds.
Now I'm getting told different things, Some people say it's the fuel pressure reg, and others say it needs to be earthed to the chassis and not use the existing wires. As far as i know, the filter sock reaches the bottom (so my mate says), so i'm not sure what the problem could be.
This is the first time i have touched the fuel line on any car so i'm a bit of a virgin to it.
I'm not sure if this will impact it, but when i was driving to go get the new pump installed, i was cruising along the highway at around 2.5k rpm, and the car hesitated for a second (lost power, but only for a second), engine light came on, then went back to normal and engine light went off.
List of engine/exhaust modifications are:
Superspark coils,
0.8mm gap plugs
3" to 80mm exhaust, no cat (still waiting for one that fits)
Pod filter with standard AFM
and that's about it that i think could effect it.
I have an AEM tru boost, but was only running stock boost when this happened.
Thank you in advance for anyone who can help.
Shaydan
i thought the 044 was an external pump and the 040 was the internal pump? maybe that is part of your problem. or it may have nothing to do with it and it may be fine
if your old pump was dodgy then putting a new pump in may be showing another issue that was previously hidden by a failing fuel pump. this may be something simple like a dirty afm or fouled spark plugs.
The stock Fuel pump was fine,
And yeh you're right about it being external, but you can still use them internally.
The FPR has arrived but not fitted and it's still 50/50, c-red and hyperdrive told me over the phone that i have wasted my money because it's not needed, and others say i need it.
I'm not sure if the FPR is related to the hesitation when in 4th and 5th.
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
