Hey mate just wondering do you need to have to get new tensioner and idle pully or can you just use old ones??
You don't have to replace them but it's highly recommended... Look at it from this perspective; will cost $200 for a timing kit which includes the bearings.. This is cheap insurance for protecting your motor. You'll be kicking yourself if one of your bearings fails and you smash the internals of a perfectly healthy motor.
  • 2 months later...
Hey guys
As many times said, well written guide, though I would be happy about more pics :)
In any case I wonder, cause the other guides I checked für Timing belt stuff are always with taking out the complete cooler stuff. OFC I saw you got this doen without, but would you say it is still makable for one who never did that before without taking out the cooler or is it more like you got the pro Hands and know every "grip"?
I didn´t get that part with the controle of the marks. So you set it all up, Tension the belt like you descriped, and then rotate with the hex ClockWise. But the marks will be right after many complete turns, is that correct? So I just turn and turn and hope that they´ll end up perfectly on the marks somewhen? If, I am ready to tighten everything and Close the case n so on, right?
Thanks a lot
What about the sentences in which they say "wont line up straight after 1 or some turns"
Yeye it is :D
Hey I´m german, I´m allowed to speak like that
Thw dots on the pulleys only line up every second turn.
The dots on the belt I'm not sure, I don't worry about them
The timing marks on the crank and Cams only line up on every second turn because the cams are turning at half the speed of the engine. 4 stroke engine = 4 strokes per cycle.
It's easier to do it with the radiator out, but obviously from this guide its not 100% necessary. I would just pull it out because it doesnt really take long and if your doing this sort of service it probably wouldnt hurt to replace coolant as well.
I think if you want to use a puller (which I would recomend to ensure the balancer comes off nice) you would need to pull the radiator
  • 3 weeks later...
  • 9 months later...
To revive an old thread - used this tutorial the other weekend to do my 200K service
The above question should have been answered by now - but if not, the CAS has slots for the 3 screws to secure it to the cam cover - making it adjustable. Put a mark between the CAS & the cam cover case so that it is set as it was prior to taking it off
The crank- like the other 2 timing marks has a little dot on the outside of one of the teeth, get a light down there and look for it.
One other thing to note after putting the belt on that I found on the nicoclub website, might explain the setting the tensioner a bit clearer
I'll be taking the belt off and re doin it this weekend & remember to do what is mentioned in the picture above
Edited by BstewyR33
Marking the cas to get the timing roughly right for initial start up is a good idea.
Relying on it to be correct for driving around is very silly.
The timing must be set with a light.
  • Like 1
  • 1 month later...
  • 3 weeks later...
This timing belt is simple. The "tensioner spring" is only used to SET the timing belt tension the first time. There is NO MECHANISM on the RB26 to maintain tension during operation. This mechanical simplicity is fine due to the fact that these cars use short and simple timing belts.
ALSO there is a very important step of checking the spring operation. They show a range of motion for it in the manual to make sure that you are getting enough tension on the belt where you are hooking the end of the spring on the stud.
Line up marks: cams and crank pulleys
Make sure tensioner spring is hooked on stud and in place and tensioner pulley is free to rotate
Use crank bolt to rotate crank clockwise at least 2 turns and SLOWLY and evenly bring timing marks back into spot (watch the tensioner as you do this...it should move around a bit and you will see how the "tensioner" is taking up slack as you rotate the engine through).
Note the position of the hex key slot on the tensioner and carefully insert hex key wrench.
while holding the hex key in position, torque nut down on tensioner.
Or in my case, thrown the belt on, didn't use the spring, check cams align with timing marks, use Hex key to tension the belt to however tight I felt like setting it, torque up tensioner, stand back look at it and say "she'll be right" and it's good.
  • Like 1
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
