Hey mate just wondering do you need to have to get new tensioner and idle pully or can you just use old ones??
You don't have to replace them but it's highly recommended... Look at it from this perspective; will cost $200 for a timing kit which includes the bearings.. This is cheap insurance for protecting your motor. You'll be kicking yourself if one of your bearings fails and you smash the internals of a perfectly healthy motor.
  • 2 months later...
Hey guys
As many times said, well written guide, though I would be happy about more pics :)
In any case I wonder, cause the other guides I checked für Timing belt stuff are always with taking out the complete cooler stuff. OFC I saw you got this doen without, but would you say it is still makable for one who never did that before without taking out the cooler or is it more like you got the pro Hands and know every "grip"?
I didn´t get that part with the controle of the marks. So you set it all up, Tension the belt like you descriped, and then rotate with the hex ClockWise. But the marks will be right after many complete turns, is that correct? So I just turn and turn and hope that they´ll end up perfectly on the marks somewhen? If, I am ready to tighten everything and Close the case n so on, right?
Thanks a lot
What about the sentences in which they say "wont line up straight after 1 or some turns"
Yeye it is :D
Hey I´m german, I´m allowed to speak like that
Thw dots on the pulleys only line up every second turn.
The dots on the belt I'm not sure, I don't worry about them
The timing marks on the crank and Cams only line up on every second turn because the cams are turning at half the speed of the engine. 4 stroke engine = 4 strokes per cycle.
It's easier to do it with the radiator out, but obviously from this guide its not 100% necessary. I would just pull it out because it doesnt really take long and if your doing this sort of service it probably wouldnt hurt to replace coolant as well.
I think if you want to use a puller (which I would recomend to ensure the balancer comes off nice) you would need to pull the radiator
  • 3 weeks later...
  • 9 months later...
To revive an old thread - used this tutorial the other weekend to do my 200K service
The above question should have been answered by now - but if not, the CAS has slots for the 3 screws to secure it to the cam cover - making it adjustable. Put a mark between the CAS & the cam cover case so that it is set as it was prior to taking it off
The crank- like the other 2 timing marks has a little dot on the outside of one of the teeth, get a light down there and look for it.
One other thing to note after putting the belt on that I found on the nicoclub website, might explain the setting the tensioner a bit clearer
I'll be taking the belt off and re doin it this weekend & remember to do what is mentioned in the picture above
Edited by BstewyR33
Marking the cas to get the timing roughly right for initial start up is a good idea.
Relying on it to be correct for driving around is very silly.
The timing must be set with a light.
  • Like 1
  • 1 month later...
  • 3 weeks later...
This timing belt is simple. The "tensioner spring" is only used to SET the timing belt tension the first time. There is NO MECHANISM on the RB26 to maintain tension during operation. This mechanical simplicity is fine due to the fact that these cars use short and simple timing belts.
ALSO there is a very important step of checking the spring operation. They show a range of motion for it in the manual to make sure that you are getting enough tension on the belt where you are hooking the end of the spring on the stud.
Line up marks: cams and crank pulleys
Make sure tensioner spring is hooked on stud and in place and tensioner pulley is free to rotate
Use crank bolt to rotate crank clockwise at least 2 turns and SLOWLY and evenly bring timing marks back into spot (watch the tensioner as you do this...it should move around a bit and you will see how the "tensioner" is taking up slack as you rotate the engine through).
Note the position of the hex key slot on the tensioner and carefully insert hex key wrench.
while holding the hex key in position, torque nut down on tensioner.
Or in my case, thrown the belt on, didn't use the spring, check cams align with timing marks, use Hex key to tension the belt to however tight I felt like setting it, torque up tensioner, stand back look at it and say "she'll be right" and it's good.
  • Like 1
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
    • This thing did a 1:20.88 at Winton on the weekend which is f**king rapid.  Well done mate, your driving has really gone up a few notches not much left on the table now! Good luck at WTAC.   https://www.facebook.com/share/r/1MHyZQBqZ2/
