Hi guys,
I have been having the same problem, to get the crank pulley off, but on automatic skyline. To remove or to tighten the pulley bolt there is no common way to stop crankshaft, like put the car in 5th + hand brake up. I designed my own stopper and puller. It cost me about 35€ and the tool works pretty well. Here some pictures:
  • Like 2
I just want to triple check. This woodford key doesnt need to slide into the gear sprocket on the camshaft right? 20191220_154812.thumb.jpg.ffa67ae8eba0a984a266f59485695c18.jpg
It's just the woodford key, a backplate that will push up against the gear when I slide the harmonic balancer on. If I recall the woodford key holds the harmonic balancer on this slot here.  20191220_154829.thumb.jpg.c346ad2036b0f5b9c1abeac292ba2768.jpg
Im pretty confident the other one is still in there. I did not remove the crankshaft gear and if I had I'd have seen it. I only removed the harmonic balancer.
So when I install it, its gonna be the woodruff key (making sure its firmly in place), then the plate that sits against the crankshaft gear, balancer, spacer and bolt then tighten to specs.
Expand
That's correct. If you didn't touch the gear no worries. A woodruff key can't slide out
  • Thanks 1
  • 8 months later...
what about torque specs when putting everything back on? there are also a few good YouTube videos to watch before just following this guide. Id recommend changing the water pump whilst you are there. Anyone know if the OEM or the same as the Greddy or HKS belt kits? I don't know If its advertising or they all are the same shit?
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
