Is this possible can you make it to think there are 2 afm? I'll be using a nistune board reason for wanting a single afm is 1 I'll be running a single turbo and 2 I don't have much room to run twin filters. Im wanting to run afm in cooler piping as well and a single would make fab so much easier
https://www.sau.com.au/forums/topic/397617-single-afm-on-a-rb26/
I recall a thread from years ago, it was either getting a Single AFM on a GTR or 2 AFM's on an RB25, but there was mention of a JAP signal bender thing that could do it
Possibly a SAFC or similar.
Can't remember the outcome though sorry but I have a funny feeling it didnt work
Maybe a single AFM would work as is.
Wouldn't in normal circumstances take the average of both. So why not the average of 1 ?
Sort of like a single 02 in one of the 2 dumps ....
Just to qualify this thought. I dont know sh!t
and to add to this thread not being a smart arse - do we have a search function in this new version ?
Hang on a second... An RB26 ECU was able to start and run my stock R33, simple plug in job.
Why don't you dummies put an R32 ECU in it and switch a couple of wires around. Voila, single AFM ECU.
I mean you don't HAVE a RB26 Nistune yet do you Blake?
The last RB20 ECU I bought was $30
It will plug in, all you need to do is swap a couple of wires and you will have a single AFM ECU in the car. Simple as that.
If I can do it, you can do it.
www.paulr33.com
EDIT: R32 RB20 and RB26 ecu's all use the nistune type 2 board. So you are really at no disadvantage to Nistune an RB20 board. Later if you decide to go back to twins you can just move your Nistune to the RB26 ECU and swap the pins back, making it twin AFM.
Ummmmm simple? Yes.
www.paulr33.com
Ummmmm simple? Yes.
Would need a board reprogramme though
Hey Blake there is a member on here his name is kristafa I think he has a black BMW 318i that he put a 26 into when I spoke to him he seem to be in the know of dos and donts with the conversion
Not relevant to the post but in general still usefull to u
you can use one airflow meter and parrallel up the signal wire to both inputs on the GTR ECU to make it thinks it has two AFMs
the ECU does an average of both airflow meters, so it is basically the same thing
the device you might be thinking of is the later SAFC II that lets you manipulate the AFMs to either single or twin AFM on single or twin AFM car
that is, run twin AFMS on a single AFM car, or run single AFM on twin AFM car
ther other device you might be thinking of is the HKS VPC or vein pressure converter that converts MAP to AFM
This!
Is what I was thinking
that is, run twin AFMS on a single AFM car, **or run single AFM on twin AFM car**
Isnt that the same thing? As joining the signal wires.
I have never attempted this but heard that it couldnt be done as the nissan ecu halves the value's for the afms.
But as u say if u join the signal wire they shoukd read the same any way
I was thinking that to just joining the signal wires I'll be doing the wiring myself and it's my first attempt at anything like this so having everything I need is handy I'll be doing it on Sunday I'll let everyone know if it works
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
