Hey dudes really need to clean this out as i no longer need these parts anymore, i would keep em but i own a S14 now.
BRIDE BRIX - good condition comes with r32 driver side seat rails, 300 bucks(firm)
r32 gts, 2.5inch cat back(drift pipes) 250 bucks
4 watanabe wheels all 15x7. 4x114.3 stud pattern. 1 rim has a bit of a dint but i used em daily, no problems. - 350 bucks
pair of impul meshies 16x7 1 in silver the other sprayed in black. multi-stud can fit on anything - 200 bucks
4 watanabe's and 2 meshies sold together for 500 bucks
a pair of gktech 30mm bolt on spacers. also comes with a bunch of slip on disc, brand new never used.
suits 4x114.3 - 100 bucks
located in melbourne
and a photo of my old R32 with the wheels.
Edited by AndreW_R32
the meshies are sprayed in black now. i am asking 150 for the pair.
the spacers im sure someone needs them, as i have 5 stud i cant run these.
the r32 exhaust, im sure someone with a n/a r32 would love to have an amazing sound and gain power :) - 250 bucks take it away or pay 300 for me to install it to your r32
might keep the meshies now, unless someone wants to take them for 200bucks for the pair.. cant say no to that.
still got spacers. sure someone wants them
exhaust i need gone taking to much space. 250bucks just take take it away. was 450 to be made, gains more power and amazing sound... featured in gripshiftslide.
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
    • Can confirm previous shop that built my motor had no fking clue about oil control and caused my motor to shit itself after two track days. Current shop, Birrong Automotive, has managed to build me a motor, not to mention, has also let me tune it myself and it has yet to blow up after 7 track days. Great oiling success, yashimash.
