  • Replies 53
Patto are you sure that is the right part number. These are the part numbers quoted by sydney kid before.
*GTST pump is 135 litres per hour and supports 300 bhp at standard pressure
*GTR pump is 190 litres per hour and supports 420 bhp at standard pressure
*Bosch 910 pump is 200 litres per hour and supports 450 bhp at 73.5 PSI # 0 580 254 910
*Bosch 975 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI # 0 580 254 975
*Bosch 984 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI # 0 580 254 984
*Bosch 044 pump is 330 litres per hour and supports 730 bhp at 73.5 PSI # 0 580 254 044
*Bosch 040 pump is 235 litres per hour and supports 520 bhp at 73.5 PSI # 0 580 254 040
hi guys
im interested in getting the Bosch 040 pump (part # 0 580 254 040)
i saw on this thread the cheapest people can get it for is $240, thats a great price. does anyone have any instructions on how to do the relay thing for the neg wire on the pump? is it bcoz the pump comes with new wiring that some people here say to use that instead of the standard wiring on the car?
if anyone could PM me regarding their price for this pump + shipping to Sydney, that would be great. postage to sydney shouldnt cost more than $10-20 which would include insurance also
cheers guys
-Michael
  • 8 months later...
if you aren't after it urgently, I will be selling my (1 year old) Bosch 040 out of my S15 in under a months time. I have bought a new Walbro pump, as it uses the factory pickup, which is better when you have under 1/4 tank of fuel. So I will be selling mine if you can wait. Otherwise I'll find out a current new price for you.
Cheers for the quick reply. . . I'm gonna hold off buying an 040 right away now because after ringing around the shops. . . I've been getting the usual conflicting information that you get from shops trying to make sell their stuff. . . Still interested though
As far as I'm aware, there are NO negative effects to upgrading your fuel pump, no matter what your mods. However if you don't upgrade your fuel pump and lean out under high load/boost/rpm, then your motor goes bang. I think it's a pretty easy equation to work out :mad:
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
