Hey; After two years it's time to replace the brake pads;
I've been in contact with Queensland friction materials they just want to know what type of calipers i have; to which i replied I think they are standard Sumitomo's; to which they replied Yeah but what type?
No frackin idea.
Here's a picture.
https://www.sau.com.au/forums/topic/397650-what-brake-calipers-are-on-34s/
Love the sarcasm/cynasism lol
Well the guy i've been talking to is quite knowledgeable about this sort of thing; i'm obviously not.
And there's actually a very good report on these very forums with these QFM Brake pads for street use
When you look at it from his point of view; I know there are many weird upgrades for certain models- Some of the skylines have Brembo brake calipers !!??
The numbers he gave me were showed he thinks they are either DB1170 or DB1220
I've checked my R34 manual; as usual it is completely useless except for showing how to top up the washer fluids.
You don't need to take te pads out it is common knowledge what pads they use, obviously old mate at Qfmdoesn't know skylines
If you tell Greg at Gsl you need pads for r34 gtt he will know what pads you need, I should know as I've bought pads off him for my r34 gtt last year and for my r32 before that
Thanks guys, and yep we can do both QFM and Remsa (and 12 other brands of pads), and carry heaps in stock ot sit GTT.
Your problem in dealding direct with QFM is that they're a manufacturer, not a distributor, so they don't have the real world experience of knowing what's what. They know part number and how to make them, and limited vehicle specific knowledge. For this reason most of their performance pad inquiries just get forwarded straight to us to answer.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
