Has anyone here ever fitted or had fitted a cruise control kit to their Nissan or other make of car? Thinking of getting it fitted to my skyline and stagea as a way of not speeding while doing long haul driving.
I cant believe that the stagea doesn't have it fitted anyway but it was never an option even though its a 2000 model and has everything else u could ever want or need.
https://www.sau.com.au/forums/topic/397656-cruise-control/
It can be done , i wouldnt ever do it on a turbo skyline , i miss it from other cars but think about it
High power car, bad roads, rb goes from no power off boost to balls out , traction control yanks the thing to damn near a crawl power wise
And turned off even a modest power line on a dry road can be a handful on bumps and put you in the trees in a heartbeat , its like driving tip toe to not fry the tires or end up bouncing off bad dips holes in the road on coilover shocks
and you cant go in back and make a sandwich on cruise control haha
Really the ecu isnt smart enough like a new stability controlled cars and most people driving skill it would kill them , plus when you get sore jump out for a stretch and wake up ? Built in safety measure lol skylines arent bad on drives just the shocks too stiff and wide tall tyres ride bad on australian roads
Maybe auto non turbo , wagon I would go for it not a big deal on that , or low power turbo or 4x4 car
New cars its not such a issue
https://www.sau.com.au/forums/topic/397656-cruise-control/#findComment-6313549
I've had turbod cars with heaps more power than my stag or 34 with cruise control and never had any issues like what u described. I do a lot of 100km trips down the mostly straight Western Hwy between Ballarat and Melbourne and always found it rather smooth in operation and rather handy. These have all been with factory cruise though, is there something about after market kits that are crap?
https://www.sau.com.au/forums/topic/397656-cruise-control/#findComment-6313611
Around here the roads suck ? it is sadalaide
Aftermarket is what a lot of cars use ( dealer installed options !) the 34 has a spot for one built in the throttle i noticed
i too had a v10 with cruise in usa but the weight of the truck and smooth power delivery as it goes up a hill made it a non issue, my old mitsu vr4 galant 5spd had one in denver but the evo motor didnt spool up like a rb , on a 14,000 ft climb it would pull nice on dry roads 4x4 car since the turbo spools faster and faster it would fly up the hill but the engine would be overheating ( even in cold weather) from leaning at altitude and being on near full boost for long times the temp would rocket up past half way even on half boost near stock car
doubt that would happen in oz but a short steep hill would
my car demands attention even around town from being so stiff and a few mild mods , 11 inch wide tires and nismo lsd ,The gtt is tail light in stock trim , low fuel not sure how the stag would be ?
i wouldnt feel safe on cruise in the 34 unless it was flat , wide , smoothe , gradients steady not steep , not raining on uphill sections
Traction control is just too abrubt on the 34 it would piss me off , cause cruise would kick off too
And without it on the car has enough power to slide on boost in 5th gear in damp conditions 3200rpm is enough to be slowly sideways on good tread rubber and in 5th thats speeding a fair bit
if you break traction on cruise and it hesitates even a split second you could be in strife , your feet wont be in a position to respond in most cases
my new model camry with a 2.3 lite engine auto had cruise and in the light rain it would spin the tyres randomly even in 5th !! and front drive is not so nice to get sliding at speed ( it had fly by wire throttle delay too)
IMO i wouldnt do it unless it was stock, auto, and no traction control overide when on
No idea of cost , in usa they ran about 300 plus install for a normal car
Stags dont use the same traction control as 34 if i remember right ?
see if chris rogers replies maybe he knows of some here ?? Call him up ??
Another option might be grab one off a us model (v series skyline) infinity g35 from a wreckers , cruise is on just about every usa car ? It might be able to be converted for use or give you some bolt on parts at least , get someone to photograph the intake throttleplate on one ?
You can source a kit from usa for any car that has a throttle cable still , stinger australia , (victoria) might even carry one they import a lot of stuff like that ? call phatt audio in braeside those guys might do them , ask for brett or sam
https://www.sau.com.au/forums/topic/397656-cruise-control/#findComment-6313683
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
