Haha if u wana be dickhead...u have a way of writing emails which cracks me up.
Those pretty stickers are good for your toolbox.
U running tomei exhaust manifolds right?
:D.
Nah mate. HKS ported me a set.
I learnt the hard way with stainless junk!
:D.
now I remember when the tomei items cracked on u. Do u mind sharing a pic of these hks manifolds, when u get the chance?
this thing is going to be off its head!!!!
Yes, I believe it will, I'm thinking when it starts up Satan will be wanting to sponsor it and any red blooded male with get a warm feeling in their pants.
I'm more partial to a startup engine sound that induces a feeling of fear... Oh crap what have I built ! Instead of one that provokes a bunch of guys to get a semi...
Fear is where its at!
So no VCAM just yet... Are you still planning on using the Mines 10mm lift cams you were talking about at the nats?
Ian. No Vcam yet but I put the Exhaust cam in that HKS and the guy that built the head recommended IF i decide to go that way later on. Actually even without Vcam Hiroyuki recommended the 264's anyway. I will be getting his 'recomended' cam settings and go from there. I'm hoping the idle will be nice and smooth, not a grumpy prick like it was with the 270's.
But fear gives me a semi
Next time your scared... don't come near me :P
Dont be near Wakie on the 19 of May then, the fear levels may drop after the first session if the engine bay isnt covered in oil.
Im loving the power of the boat ATM but the oil issues are breaking my balls, hopefully will be fixed after the new cam covers/baffles and catch can are in.
Either that or Im just going to go and buy some Drag Radials for the rear and only go in a straight line, the car has no problems doing that, stupid f**king car.
Well hopefullt this does it. You can't have any more black lines in your bay. It will look like a spiders web.
Have you got your latest graph handy? Throw it up if you could be bothered!
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
