Nick, I don't know man. I said 6 weeks... 6 weeks ago. Can't be too much longer. I've lost a little motivation at the moment but I'm sure that will change when the engine is 2 meters in the air!
Sounds like you better fit a set of wheelie bars son.
I think this thread needs to be locked if action isn't taken soon
You take that back! :P
ATM i'm waiting on everyone else.
Yavuz has one of my JUN cams, have recieved a call for the engine/order head gasket (as we dont know what size we will need) and "balance tube" is in Japan being tickled.
Hurry up dammit!
Just waiting on the engine guys. Head gasket arrives this week.
Had a few things sprayed black. Surge tank, Nismo plenum and AFM blanking plates.
Other than that, nothing to report. Once the engine gets back it will be on like donkey kong :D
  • 3 weeks later...
Still waiting the phone call for the engine. Yavuz has one of my JUN cams for a little bit of "R&D". More on this later on :D
However a Precision 6466 CEA Twin Scroll 0.84 got ordered today. Didn't see that coming hey mate ;). Nor did I two weeks ago! Haha
will be interesting to see how the 6466 goes on the 2.8. Should be fun :yes:
Well seeing how well the 6262 went on Jez's standard 2.6... That first full power run on the dyno is gonna be a damn interesting!
Are you going single turbo setup up?
It's the smallest twin scroll there is.
you can fnd one that will may fit . 0.58 0.70 0.74 they are not made by precision.
keep in mind these turbo's need big boost to work as the comp housing AR are high.
Also what manifold will be using ??
i no its making me sad : (
i loved the idea of a factory engine bay and exhaust with 450kw.........
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
