Nick, I don't know man. I said 6 weeks... 6 weeks ago. Can't be too much longer. I've lost a little motivation at the moment but I'm sure that will change when the engine is 2 meters in the air!
Sounds like you better fit a set of wheelie bars son.
I think this thread needs to be locked if action isn't taken soon
You take that back! :P
ATM i'm waiting on everyone else.
Yavuz has one of my JUN cams, have recieved a call for the engine/order head gasket (as we dont know what size we will need) and "balance tube" is in Japan being tickled.
Hurry up dammit!
Just waiting on the engine guys. Head gasket arrives this week.
Had a few things sprayed black. Surge tank, Nismo plenum and AFM blanking plates.
Other than that, nothing to report. Once the engine gets back it will be on like donkey kong :D
  • 3 weeks later...
Still waiting the phone call for the engine. Yavuz has one of my JUN cams for a little bit of "R&D". More on this later on :D
However a Precision 6466 CEA Twin Scroll 0.84 got ordered today. Didn't see that coming hey mate ;). Nor did I two weeks ago! Haha
will be interesting to see how the 6466 goes on the 2.8. Should be fun :yes:
Well seeing how well the 6262 went on Jez's standard 2.6... That first full power run on the dyno is gonna be a damn interesting!
Are you going single turbo setup up?
It's the smallest twin scroll there is.
you can fnd one that will may fit . 0.58 0.70 0.74 they are not made by precision.
keep in mind these turbo's need big boost to work as the comp housing AR are high.
Also what manifold will be using ??
i no its making me sad : (
i loved the idea of a factory engine bay and exhaust with 450kw.........
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
