Still waiting the phone call for the engine. Yavuz has one of my JUN cams for a little bit of "R&D". More on this later on :D
However a Precision 6466 CEA Twin Scroll 0.84 got ordered today. Didn't see that coming hey mate ;). Nor did I two weeks ago! Haha
that was definitely out of left field, I thought for sure you would say twins, but I've seen this sort of thing before, first it's a big single then it's No2 and before you know it there is a 3.0 on its way :yes:
I agree... All I can remember is .... -5's -5's....
In the end it doesn't really matter... Just don't take too long in making it drive again. Have the car off the road for too long while changing too many things and you will lose the passion for it.
Or worse, You'll do something really silly like spending an extra $30-40K on it, and then end up selling it!
Oh i know, but when a little SR is beating your -5 graph both down low and up high with one of these things, not to mention Jez's result it's really saying something.
If it's a huge flop then nothing is stopping from bolting the little baby -5's back on.
No N20. It's not "street legal" :woot:
If the 6466 is too big i'll just pull it off and buy a 6262 or 6266. Keep that turbo for Motive DVD event's.
it's only illegal if you get caught, :yes: I notice there was no denying the eventual possible use of a 3.0 though :whistling:
This is exactly what my god brother did back in the 80s as I remember as a kid. Built a HQ monaro with a blown 454 and in the end after spending a lot of money as all parts were from the US - he sold it in parts. All he had to do was assemble the thing.
Paul - good on ya for going single. You are chasing top level results and I'd it means using a single, so be it :)
Don't sell your -5s just in case.
Nah Marko. The 5's and all the pipe work will go on a shelf in the garage all wrapped up. The condition is that this precision must beat the -5's in all areas!
Jez matched the -7's with a 6262, you'd think I can match -5'a with the next size up.
Also, spoken to Yavuz about engineering it AND passing emissions. That was another 'condition'. Both he said would be no problem.
pop the bonnet please sir..........
Should sound sweet :D
The first day he drives it out if UE with a single he'll get pulled over haha
Hopefully not (touch wood) :D
Let's get this beast on the road!!!
Narrowed down what manifolds to use Paul?
Lol. Don't say that man! Yavuz said he will engineer it also.
Not yet. Can you only get full race manifolds from the states or is there a local distributor?
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
