I no, i mite one day come to like them if I can sort what ever is wrong with the dam things.
Anyone got any sudjustions ?
Any "up, down, up's" in size in the exhaust?
Cam timing?
Tired engine?
Should be bout same as mine as almost same set up , i think should change cam timing to what mine is :)
The exhuast was farked when it made 330rwkw, 2.3inch front pipes into a 3inch catback than went down to 2.5inch in the cannon.
It's now got 3inch tuned length front pipes into a 3.5inch merge. Decat, and I'm just waiting on the 3.5inch tomei ti catback to turn up.
See how it all works out when the new system on bolted up. Than jez can do a full tune on it, cam gears, and all.
It's got type b pon cams.
Azza's made awesome power on the same setup I the same dyno.
His got a forged motor, but my motor is 160 across all 6 so it shouldn't b an issue.
C what happens
Not exactly the turbo's fault with the little 5's trying to blow out of that man.
So what's considered responsive with -5's? 1 bar at 3600 rpm?
from memory my rb2630 with -10s made 1bar @ 3krpm, I'd need to dig it up as I posted my results in each gear on gtr UK forum
Yea I no, the prob I had was I made up at 4inch system took it back to the dyno and only made 7kw more.
Im just saying -5 on something like your motor is crazy. It deserves a decent turbo. Gunna b awesome!!
Next time your under the bonnet man, could u have a look at what yours are set at? Maybe take a pic?
Let me know when your back and i will meet you at Jez' s and we will have a look :cheers:
You won't get that on a 2.6l unless it's fully loaded up :)
On the street it's around 4000-4200rpm in 3rd for a 2.6l if memory serves me correct
u are the first unhappy -5 customer I have heard...am I allowed to ask who is your tuner?
Add me to the list then for street/hill runs/motorkhana stuff the -5s are shithouse on a 2.6l
Cars was significantly faster with the smaller turbos coming on much faster in a on/off throttle scenario as -5s are lazy and need a stroker.
Interesting as I found my other gtr with -5s very responsive. That was a 2.6 as well.
What do u think is a good turbo for the application u refer to above?
Its not a loaded question- just like to hear your opinion.
Well given I've said many times over that I had -9s taken off to put the -5s on (so i can comment on both, unlike most)... Wouldn't say it's particularly difficult to come to such a conclusion :merli:
I've had GTSS, GTRS & -5's on a 2.6ltr (as well as -10s on a 26/30 which Paul has driven).
^ Absolutely you can comment on -9's back2back with -5's as you've had both...really is horses for courses though as I personally found GTSS's way too small (not sure how -9's compare to GTSS though)
I think it depends on the sort of driving you do. Guys that do the 'on/off/on' driving IE hillclimbs, skid pan work and track work will always favour the small stuff.
Steveo overlayed a 2.6 with SS's and my 2.8 with 5's and down low they were pretty much the same. Top end, well we know what happened.
2.6 with -5's is still lethargic, however peoples definitions of being lazy/lethargic/laggy are all different.
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
