Finally got through your thread Paul!! There is so much sh*t talk in here....
I think my SR is the engine that finally converted Paul to going to the dark side with a single.
Here is an overlay of my car (black dots) over Paul's graph. I'm running same boost in the midrange but mine doesn't fall over up top. Both are on Yavuz's dyno. Somehow I don't think its the engine alone (it is a built and stroked VE sr) and the turbo has a lot to do with it (6262).
Pretty interesting it made more power down low and also more up top with some losses in the midrange.
Yavuz wanted to keep going, adding more boost but I reckon that is more than enough.
Also, FWIW and those interested in buying a manifold, I had a extremely ordinary service and product experience with Alpha Omega....
pretty interesting. It would have been interesting to see how far you could have gotten to with the boost, but like you said, thats pretty ample for a sil! I have seen the graph, and for a turbo of its frame and capacity, it almost makes you wonder how it does it. I have also jumped onto the PT bandwagon, cant wait too see the results :)
Hi James - you are very quick around the creek (1.39.6) & wakefield (1.04.07) with < 300kw
Must be a weapon of a car!
Thanks Marko. Its definitely 'interesting' to drive even with the old 265. Still haven't got to drive it since the new engine, its just a dyno figure at this stage!! Just have some niggly issues I want to get right before I get it properly tuned.
Don't to clog up Pauls thread. Build thread is here if you're interested - http://www.nissansilvia.com/forums/index.php?showtopic=520202
I agree. I thought it would be quite a bit laggier. I was a bit worried it might not really come on until 4200-4500. The precisions aren't really good quality though... I don't have much faith in it lasting... The casting and bearing and general fit and finish is a bit average but we'll see how long it lasts. I'm not expecting much though to be honest. The wheels are just so much better than garrett though its just too hard to ignore.
Time will tell James. There was a hell of a lot of PT's at WTAC and I didn't hear of any failures.
But surprised they're not watercooled though. Must be some reason for that!
yeah. Interesting about the lack of water cooling on these turbos. But then again, they were around for a looooong time without it too. A random stab may be to keep it in a particular heat range to get the best out of it. Ive seen and heard of weirder things lol
A little update.
Got the engine back on Friday arvo. Can't get some of the pics to work. Stupid things.
Manifold to gasket size.
Exhaust port to gasket.
Another picture.
Turbo's are almost done. Just need to do the drains and the top lines. I stopped because the sun was burning me! haha
Slack! Definitely starting to come together.
As mentioned in PM very keen to see the overlays from the twins to the single PTE
Oh there will be graphs, when I don't know. After being off the road for so long I want to enjoy it for a while. I'll cant help to think I've gone a bee's dick big. There will be a 6262 thrown on and tried too at some point.
duno if i missed it some where but what Tomei stroker kit is it? (cooling chanel? tiatan coating? normal kit?)
and are you running this on pump fuel?
Tomei 2.8
Non cooling channel. Had 2 thou clearances the last engine and never had issues.
Top ring is Ti coated. (last engine had a standard Tomei top ring).
I have the "flex fuel setup". So when I'm belting it, it will have E85 in it. On the street it will have anything between E85 and PULP.
Tomei 2.8
Cheers mate, i was looking into the kits last night coz i think it will be easier to just chuck in a 2.8 crank rods and pistons into my engine already as thats all id need to change instaed of going 3L.
you can re use the existing head studs and all that stuff right? just need new head gasket and bearings?
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
