Rang the guys at UE today. A new set of injectors are in the car. It hasn't been ran up under load yet so we don't know if thats the issue. Tomorrow we will know. I have a funny feeling its a valve spring. Stupid car!
I wouldn't think it's a valve spring because you say it only does it when loaded up .. A dud valve spring & it would be rooted everywhere .
At 19 psi it happens at 7000 RPM
at 26 is happens at 5000 RPM off
at half throttle we can turn it to 8500.
More pressure behind the valve forcing it open? I'm sure the ramp rates of these cams are not helping the situation haha.
I had a miss with my other gtr and the cause was a faulty coil pack (what do u expect after 20yrs of abuse). Splitfires fixed that.
However, your above post throws my theory out as it definitely sounds more mechanical. I agree with u paul but its not an educated guess.
Definately not coils. Borrowed Joey's set which did 430 ish 2 hours before hand.
Wasn't this a freshly built head with new springs etc ..
Hmm it's strange alright but I would still think if a spring was off you would still encounter problems at 8500 rpm .. But it doesn't do it at partial throttle.
Everything in the head was brand new. The springs are HKS step 2's. Maybe due to the fast closing of the valve it's just enough to cause issue with higher boost at higher RPM?
Shim the valve springs. They need more seat pressure!
What Sean said . I tried looking for the spring pressures on HKS step 2's , but can't find figures .
It would seem you may have a much too aggressive profile for the springs .
    • My R33 never ran more than stock boost but it was unclear whether the turbos would last. Maybe OP's car is less of a question mark but for my stock turbos had over 175k km on them + 25 years of use. That's a very long time to hope nobody has ever accidentally put physical shock through them, no debris in the exhaust gas stream, no boost leaks that could cause the compressor to spin faster than it otherwise should, no oil coking in the journals, no wear scars for any reason, etc. You could pull the turbos and disassemble to inspect/overhaul as needed but for that kind of effort you may as well replace the ceramic turbine with something that can take a bit more abuse no matter what you find in there. Stock boost ceramic turbos really don't make that much power either.
    • A Pillar forward?   The part above I was just looking at was the reo bar, I'd replace it, UNLESS the panel beater is GOOD. From your early photos, it did look like the chassis might be tweaked, or at the very least there was tweaks in radiator support. I'd personally do a new / second hand unmolested reo bar, and drill it, only so I know underneath the pretty painted front bar, there's not a mess of other metal that's been hit and smacked.
    • Yes no yes. Pineapple rings do do a certain amount of subframe "locking up", in that they do add some resistance to lateral movements. But the primary reason they exist is to alter the driveline angle. Depending on how you install them you can either increase or decrease rear traction __ a little bit __ by changing the angle of the lower control arms relative to the car/pinion angle. The thing is, given what they are, how and where they are installed, their lack of engagement with anything in particular, there's a limit to how much benefit they can offer. The GKTech collars put metal into the space in the stock format bushes, thereby limiting how much give they have. The rubber is still there to take up some force, albeit perhaps preloaded a little by having some extra metal jammed up into it, but the increase in stiffness comes from making it so that the stock format bush can't deflect that large bit of rubber over into the space adjacent to it, in any direction. Top AND bottom. Which the pineapples certainly do not do. As I said in my other thread - I'm convinced.
    • Also, if you're into customizing your ride, you might want to check out tesla accessories model y for inspiration on screen integrations and functionality.
