its ok pauly, i know how good your massages are. Ignore all these haters, they be jealous baby. Ps. Tell yavuz ily. You at the races on cans?
Yeah man, down at the F1. 8 of us. :D
Car got ran up yesterday with new injectors. Negative. Yavuz has pulled 35% of charge time from the coils and it still fires so that rules that out. Going to try new plugs with mega small gaps to totally rule that out then we will change springs.
Well it doesn't leave too many things it can be now . Just hope it is a plug problem , quick & easy in comparison to a spring swap .
Btw , what plugs are you running? Coppers or an electrode-less type .
I have a feeling it could be a sticky spring with these cams mate. Have they checked for bind and the progressive spring tension? With the ramp on the valve train it is a likely cause.
Seat pressures are 48 lbs on the intake and 50 on the exhaust. Not much over standard which is a bit of a shit go considering these are "Step 2" HKS. Once again, the Jap stuff is mild as!!!
Just coppers mate.
All I can say to you Paul is that I hope you fix this soon because tomorrow is F1 race day. So get a few (or lot brewskis) into ya and forget about tuning the car right now.
And yes im on to my third beer and life is good.
Bit hard when you're staying with your tuner ;). As for beer count... Not sure. 12 plus so far? Quiet night... Big night will be tomorrow haha
Should be more like almost double those figures for the sort of rpm/boost you would be running. Like around 80-90 lbs. Perhaps with your new aggressive valve train/cam setup the valve springs were not spec'd correctly and your getting some valve float in that upper rpm range.
We think that's exactly what's happening. I spoke to Yavuz today and when we are both sober we will sit down and talk about what we need. We also need to factor in the new cam we are going to try soon. Something around 255 @ 11.3 with a HUGE ramp, so we need a spring to be able to close the valve at high RPM.
  • Like 1
Well it seems like the logical explanation. There doesn't really seem to be too many other obvious options left that explain the problem.
Definitely sounds that way. I'll be devastated if we change then and this issue is still there.
Mine's do cams of similar spec if I remember correctly
OK guys.
I was out at Unigroup today. New (stiffer) valve springs have been ordered. They will be here on Tuesday, hopefully installed on Tuesday/Wednesday. Yavuz wasn't there so I dont know the details but i'm sure they are more than sufficient for the task!
Now. I have some overlays
408E824D-9A03-4A70-BD6E-5B1528A30784-158
This graph is the only two runs we have done with the boost controller on so it's hardly 'optimised'. We did those two runs with the controller on when we were trying to diagnose the "miss". Funnily enough the curve starts to flatten off as soon is it does it's thing. Either way, im very happy with the midrange this thing is putting out! (No cm timing has been played with yet.... It's as the engine got put together. Also, at 19 PSI we have seen 417 rwkw. I can't remember what RPM that was at. I forgot to get a graph of that run)
5398CC6B-5BAC-4962-A3A5-4704EA38B086-158
Playing with the computer, I dug out these two graphs for a comparison. The black line is my first ever tune with the GT-RS's on pump fuel and the red line is my finished tune just before the engine died last year. Funnily enough, the boost controller was turned ON with the RS's and OFF with the -5's. Haha!
I think I need new tyres! :D
7DCAA74A-93E3-4813-B58E-41F4AC719280-158
wow! looks like a gain of 50kw @ 4krpm!
must be happy & must be hanging to drive it
so with the gtrs's u were making 200kw @ 4krpm & now you are making ~340kw with -5s & latest setup :)
what is the difference in the run with the blue line v's the brown line (in the 1st graph) or is it just 2 runs where you were trying to diagnose the miss?
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
    • Yep, agree with all of the above added on too. I just love the age old "what boost were you running?" Question without getting any other surrounding data. IE, may have ran 20psi, and lived for 12 years, but it was an 80 year old granma driving it to Bingo once a week and never took it over 2500rpm.
