Fkn Marko! Haha
18 x 10 + 12 they are. I should have taken a photo of them. They look pretty fat. I think they would sit a tad better on a 10.5 inch rim but meh.
Just hurry up farken. I wanna drive the arse off
It!!!
Box is built, it ain't very often you hear of rear diffs busting, front diff.... I hope not hahah.
You do in GTST, just ask Dave :ph34r:
Haha cant wait to see the results :thumbsup:
In my mouth!
Ohhhhhhh dear!
Have you converted to the dark side Paul.
On a serious note what fuel setup are you currently running on the car i.e. surge tank, fuel pump etc...???
Ohhhhhhh dear!
044 intank lifting to a 5 litre surge tank which sits under the boot. Then two 044's which have just been staged feeding the engine. Two 23 Micron filters before the engine and checkvalves on each pump. -6 lines to each side of the fuel rail, -8 out to turbosmart "FPR 2000" fuel reg.
Yavuz has also set up fuel temp correction (measured by the ethanol content sensor). A fuel cooler with ducting will be added in the near future.
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
    • $350 for a skid pan is a joke, cost of living is definitely more in NSW 😂
