Piglet's Rebuild Of His Busted Tomei 2.8
83747408-BDED-481D-A4E9-C644DF3AA119-142
Picture I took this morning with all the covers on. Still need to order a new radiator shroud though.
Also one of those radiator deflector thingos to cover up the horns and A/C fan etc :)
Stop being a lazy fkr and come pick it up :)
Yeah, ill get there!. Time has not been on my side! Grr.
Question for you Nick. Where is your GT PRO set to? Mines at Medium and it's one aggressive mofo. I may need to back it off a tad.
I need to find an ARC one. Not a fan of homo carbon crap.
I was trying to get an ARC one originally but come across my Alloy one on Ebay randomly! Was already sprayed black too :woot:
Black... The new... Shiney? Lol
I remember when first speaking to Alex @ Plazmaman about 3 years ago and i was ordering the stealth kit and he said that Black was to be the new Chrome :P Its Black Bling!
Id have to check with the boys that installed it, im not too sure
raidator guide
tits on a bull
Not when you are talking about the cosmetic stock looking finish! When you pop the bonnet and look down it look a bit average without it! He has gone so far with the presentation it might as well be finished off properly ;)
question, how does the air get to the air box intake if you block the airs path from the grill with the radiator guide ?
You can see the big gap in mine so it would still flow plenty of air... Although I haven't worked out a snorkel setup for mine as I wasn't clever enough to use a stock airbox :(
Oh yeah, scrap that idea!
Im sure brad at profab would be able to fab one up out of sheet ally and in corporate a funnel to the air intake from the front grill.
Then just paint it or powder coat it the new shiney lol.
:yes:
Mine had a shield/guide but it also had a 100mm hole in the guard with some NACA duct tubbing from under the air filter shield to the front grill, plus there is a heap of air voids around the front headlight to allow air to flow inside the air box if it has a opening on the front side behind the headlights.
No good for the ARC box I believe though, but good for a enclosed pod set up.
LOL, just saying.
Rightio. SO after 2 days of 11ty strings around and under the car, deflection gauges, tape measures, more strings, more measuring and even MORE STRINGS, I have a piece of paper with words and graphs. 7 pages of graphs and jargon that I hardly know what it meant.
From what I CAN gather from it. I will need to purchase a roll centre adjuster setup for the front. the HICAS lockout bar needs to be moved up 10ish mm to help eliminate bump steer in the rear. (Design fault possibly). The shocks will be Bilstien with a PSS9 body - That's where the similarity will end. From then on its all Dejan's specs. His valving, gas, spring and oil combo. People may laugh, but the spring rate in these will be about 20 KG/mm BUT it will be very pleasant on the street. They will be height adjustable and damper adjustable.
A little bit of testing and these will be available for R33 GTR's as a bolt in kit.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
