Piglet's Rebuild Of His Busted Tomei 2.8
Dunno why it broke.
I pulled the boost down to 1.5 bar (minimum I can run). Came in second session and second gear was knocking. Terry at award thinks its a bent or broken gear.
Dunno when I'm gonna pull it out. I'm a bit heart broken ATM.
i feel for ya man.....I really do. However, I'd be wanting to find out the cause of said broken gear as OS Giken Gbox should be capable of handling your cars power output
Power maybe. Torque ? Seems not! :(
The PPG boxes if put together properly seem to hold together behind RB30s and big power...though never seem a helical gear set being abused...always the straight cut boxes behind the track car setups
If I could quote both on my phone I would!
Ants; it's the torque. Twist x RPM = power. Bah.
BBQ Sleeper; I know what you're saying. I'm
Not one to be hard on the equipment. Hell, I turned the boost down and was shifting at no more than 6500 RPM. I never shift hard. Grr.
and that's what concerning to me.
Lol twisted gear set on a 2.8 litre with too much "torques"
Lol sounds like a farken assembly problem or bearing issues Eg assembly problem
Billet metal doesn't "bend" under 2.8 litres of nm
Just saying ... Unless your 2.8 is a 6 litre turbo diesel
this man ^ he knows
Award f**ked up?
Hoping its a collapsed bearing. I've rung Terry and he hasn't given me good news.
time to start monitoring gearbox temp
please post pics of the failure so us nerds can analyze it!
Will do.
I can't see it getting "too" hot in a ten minute session.
The is gear set is rated for 800hp and if you do the math Paul's car is making some where around 750-800 at the engine, which puts the box at the top of its capabilities
Ye
Id put it at at 730-740hp at the crank
And you can really rate a gearbox by horsepower. Os should rate then by torque.
475kws is 617hp at the wheels now with an average drive train loss of between 20-30%, you're looking at 741-803hp at the crank and even if you take the middle ground of 25%, it's still 772hp
And the fact this car is making 350kw by 4500rom says it's making bucket loads of torque right through the rev range
+1 indeed.
So, after Tuesday, it looks like I have broken or bent a tooth in second gear.
Time for another aftermarket gearbox.
PPG straight cut dog box? The OS 5 speed doesn't cut it! :(
Transfer the money and I'll send it up..
You'll have to get rid of your nismo clutch though.
Lol.
Yeah, no.
There is nothing "street" about a holinger box.
Hang in there Paul, sure it can be heart breaking with things break but its part of playing with performance cars too....
I'd like to know how noisy a holinger is compared to a normal box too for streetability. If your not driving the car every day, who cares if its not a lot of fun in 3 point turns.
Have you thought of using an R34 getrag? With the R33 diff ratios it would handle more power, plus they are nicer to drive than an R33 box and cheaper than a holinger or built box.
I've thought about the R34 box. Are they really that strong? I liked the long ratios, it worked well. With the getrag and 4.11's it would go back to "Evo like rowing gears", which is something I don't think I'd like.
Holinger.... Nah. $20k for a box. Blah lol
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
