Piglet's Rebuild Of His Busted Tomei 2.8
Have you thought about getting the nismo getrag conversion for your r33? I know its a bit expensive but surprisingly you get a fair bit of stuff for the money and its all new including the box
http://www.nismo.co.jp/en/products/competition/mission/getrag.html
It is an option. You don't hear of many going bang but really, how strong are they?
Getrag and 4.11's would be crazy short. I'd say there would have to be a diff ratio change in order.
What is the Getrag's limits? I know PPG do a set for them but that's the best bit of $10k for the spikey wheels and associated bits themselves.
PJs Helical dog has had one dog ring changed in all the time he has had the box in his car.
75% is street driving plus countless 10,9 and 8 sec passes.
His car hooks better than most AWD :)
How long has it been in the car?
First hand.
I owned a straight cut dog engagement PPG box for about 4 years. Drove it occasionally on the street, mostly in tarmac rallies etc.
It was rebuilt/refurbished every year without fail, regardless of how it was treated. They just don't handle power as well as people say.
Paul's car will certainly stretch it's limits with 470kw on tap.
These boxes prefer to be shifted hard, the slower you engage the dog rings the more damage you do to them and the gears. It's not always apparent until you pull it down just what slow shifting (street type driving) does to the box.
I sold it and went Holinger. My Holinger is helical, not sure if they all are. It's quieter and easier to drive at any speed without doing damage as a result.
I rebuilt my Holinger pre WTAC and parts alone was $5k! Nothing's cheap or bullet proof when you're chasing big power unfortunately.
There's no simple answer, other than keep saving your hard earned....
How long was the Holinger in before that?
Too much servicing costs, bugger that!
Terry just rang. 6 speed won't cut it, he does heaps of them. OS there is a massive delay and won't cut it anyway. He is looking into a custom straight cut set with a helical 5th that's synchro which uses the Series 3 internals.
*waits patiently*
What it comes down to at the end of the day is cost and luck.
I can afford to put stockers in every year or so, I can't afford a big $$ box then have it pulled down every 2 years for inspection and then possibly replace expensive parts. Billet selectors are $500 each for example.
On the other side you can have a freak stocker or freak billet set last for years and years.
It's just such a jerk of a job.
The stocker didn't last at 370.
See what sorta prices Terry comes back for this custom thing. If its reasonable, I have 4 mates that will snap one up too.
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
