Piglet's Rebuild Of His Busted Tomei 2.8
Some sort of progress.
Emailed PPG yesterday and asked if they will do a straight cut 1-4, helical 5th synchro box for me. They said yes!
Waiting on pricing.
They did say, it would be a good idea to go to the bigger input which will mean clutch modification, so ill male some calls with that tomorrow.
When you removed the Active LSD did you have any issues with the ABS not working anymore? Did you replace the ABS computer or leave in the one it already had?
No issues with ABS at all.
When I changed the front diff it played havoc with the rear though.
Waiting on pricing.
So will it be syncro straight cut 1-4 helical 5th?
Yeah mate.
Not keen on dogs and I can deal with a bit of noise in the lower gears.
Apparantly PAR do what I'm after but I want a PPG set.
This set will use all the Series 3 33 gear inside, so servicing shouldn't be a drama.
Should have a price tomorrow.
At the end of the day, it's still a street car with full interior. I don't mind chucking the keys around, so if I have a hard to use/expensive to repair box, it sorta takes the "easy to drive" away from it.
Will the straight cut fix the 2-3 issue if it's still syncro? From my time with the dog box think I'd rather the dog gears than straight cut especially at your power level shifting speed is so much quicker. After some practice u get pretty smooth mine lasted 4 years and probably 15k km's without issues or servicing until I sold it.
Bah. The guy misunderstood me with what I wanted. They won't do the "mix n match". He is trying to sell me the dog set, saying his old lady drives it no problems.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
