Piglet's Rebuild Of His Busted Tomei 2.8
OS twins are scrub too.
The larger input shaft is nice but isn't that necessary. I had to upgrade my clutch hub which was available for my Carbonetic twin clutch. Fits good.
I don't think they can mix much but PPG 1-3 dog and 4-5 synchro (or was it 1-4 dog) was a kit I thought and is ok on the street. Big power most times need big gearbox sadly.
Yeah, that's what the guy I'm talking to said he could do. 1-4 dog straight and 5th helical synchro.
I need to drive one to get some sort of idea of what these dog boxes are about.
Just throw a rb20 box behind it and forget using ya front wheels, guaranteed to hold as much HP ya can throw at it :P
lol but on a serious note go the PPG 1st-4th dog and 5th helical synchro. There's honestly nothing to them. You dont have to drive them hard or abusive as so many people say, it does them no harm driving the PPG dogs softly. Ive driven one personally in a mates old r33 26/30 GTR. Was intially a little strange and kinda didnt like it but as the day went on and I got use to it, it grew on me. Although I will admitt im unsure of servicing costs. He had it 2yrs/20,000 odd km's with no hickups supporting around the 500kw mark in that time. This is probably useless info to you paul but thought id voice my opinion haha.
Now back to the BEERS! :)
http://www.rhdjapan.com/os-giken-close-gear-kit-5-speed-nissan-rb26dett-input-shaft.html
$2800 Paul, not sure what you're looking for but that's a pretty decent price.
I think I am going to do if it stays like that a little while!
As Brett said. Also, good luck getting one. A fellow member has had one on order since June I think. Delay, delay, delay.
I just got a lengthy email back from PPG. Gonna call him on Monday and organise to fly down to Adelaide and drive the different boxes. He said that the helical, synchro set will do the job but really is pushing the dog set. He owns a GTR with that box in it. Been in the car for 6 years/40,000 kms and its all sweet.
Interested to hear how it goes. I'm looking at the 6 speed PPG dog set at the moment to replace the standard getrag gear - waiting on pricing back and how customisable the ratios are.
Like you have never driven a dog box but street manners less important for me - it's already a pig on the street!
From what I can gather, I don't think they like to budge on the ratios they have on offer.
Ill sit down and work out the difference between standard 34 ratios and the PPG ratios, then throw in what they are on 4.11's.
I have one of the early 1-4 helical PPG gearsets... Good thing and once you learn to drive a non syncro box it's a lot more rewarding to drive. Plus if my missus can drive it successfully, anyone can.
OS triple is the worlds most brutal and hardest clutch to drive. I had one and was absolute rubbish.
... ba ha ha ha ha ha. Once you set the pedal height properly, it's not really that bad. I've driven much worse.
... again, if my missus can drive it in traffic... you must be doing something wrong.
Just a note on input shafts.. I opted to leave my input shaft stock. I look at it as a fusible link, as my clutch is unlikely to slip too much... so the stock shaft provides some protection to my gear set if serious shock loading occurs.
Cheers
Justin
  • Like 2
Cheers
Justin
i wish to like your post more than once
Cheers
Justin
So you reckon the dogs ain't that bad?
I've spoken to PPG the other day, damn long phone call. He is getting back to me with pricing on the straight cut synchro IF they're willing to do it.
The guy I'm dealing with has the helical dog set in his own GTR and loves it. Just need to drive one to see what the go is.
Cheers
Justin
Is your missus a race car driver?? :P
  • Like 1
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
