just putting these out there 7k delivered
older style so ( parts may be hard to come by)
http://page3.auctions.yahoo.co.jp/jp/auction/c435357961?u=%3btokusan707
is HKS manual transmission. There is no oil leakage and noise. Dirt.
It becomes the 6-speed MT. ATS carbon twin plate clutch will also be set.
Thickness of the disc of the ATS clutch is 3.7 mm ① 3.7 mm ②.
Gear ratio of HKS mission is the version Ⅱ of 2.701 ② 1.904 ③ 1.343 ④ 1.000 ⑤ 0.832 ⑥ 0.734 ①.
trust 6 speed 7 k delivered
http://page22.auctions.yahoo.co.jp/jp/auction/l213425216?u=%3btokusan707
trust made ​​dog clutch-type cross mission do. There is no oil leakage and noise.
There is dirt. ① speed 2.782, ② speed 1.938, ③ speed 1.506, ④ speed 1.178, ⑤ 0.920-speed, gear ratio is 0.777 ⑥ speed.
That's good to know, cheers! What does it drive like?
I'm really liking this getrag idea. Does anyone know what tail shaft to use with the Getrag in a 33? I know you use the R34 front shaft but not sure on the rear. I'm assuming the 34 unit also?
I had a Getrag with everything for the conversion and didn't do it... I don't think it was much of an upgrade in retrospect in terms of strength (besides the ratios) and it is generally accepted that they are not rebuildable (even though people do), and spare parts availability is an issue. So I got rid of it... I agree with the fat man.
Everything is available either ex Nissan or ex Toyota, it's the exact same box as the Supra box apart from the rear end.
Always thought those Trust boxes were pretty interesting. 2 overdrives and no 1:1 gear.
They're not the same box. The gtr version, the gears are not as wide.
The getrag with 4.11's will be silly short, but I have a source for 3.545 diff gears. Talking to the guys that have the same grunt, give or take, they have said the boxes hold up. IF it does pop, the PPG dog set will go in. Ratios to die for.
I'm surprised to hear that the getrag is up for the task
MAY not be, but if I be nice to it, it may last a few years, I which time I can save for what will eventually go into it.
Car has only done 3 kms this year. Need to get back to driving it :(.
Just saying, go sequential, you won't look back :)
PPGs are strong, how strong is a different matter, the BSM car went through a few of em to while they still had restrictors in limiting power to about 300rwkw, very torquey motor though
And for what it is going to cost to set up the Getrag your not far off the OS88
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
