just putting these out there 7k delivered
older style so ( parts may be hard to come by)
http://page3.auctions.yahoo.co.jp/jp/auction/c435357961?u=%3btokusan707
is HKS manual transmission. There is no oil leakage and noise. Dirt.
It becomes the 6-speed MT. ATS carbon twin plate clutch will also be set.
Thickness of the disc of the ATS clutch is 3.7 mm ① 3.7 mm ②.
Gear ratio of HKS mission is the version Ⅱ of 2.701 ② 1.904 ③ 1.343 ④ 1.000 ⑤ 0.832 ⑥ 0.734 ①.
trust 6 speed 7 k delivered
http://page22.auctions.yahoo.co.jp/jp/auction/l213425216?u=%3btokusan707
trust made ​​dog clutch-type cross mission do. There is no oil leakage and noise.
There is dirt. ① speed 2.782, ② speed 1.938, ③ speed 1.506, ④ speed 1.178, ⑤ 0.920-speed, gear ratio is 0.777 ⑥ speed.
That's good to know, cheers! What does it drive like?
I'm really liking this getrag idea. Does anyone know what tail shaft to use with the Getrag in a 33? I know you use the R34 front shaft but not sure on the rear. I'm assuming the 34 unit also?
I had a Getrag with everything for the conversion and didn't do it... I don't think it was much of an upgrade in retrospect in terms of strength (besides the ratios) and it is generally accepted that they are not rebuildable (even though people do), and spare parts availability is an issue. So I got rid of it... I agree with the fat man.
Everything is available either ex Nissan or ex Toyota, it's the exact same box as the Supra box apart from the rear end.
Always thought those Trust boxes were pretty interesting. 2 overdrives and no 1:1 gear.
They're not the same box. The gtr version, the gears are not as wide.
The getrag with 4.11's will be silly short, but I have a source for 3.545 diff gears. Talking to the guys that have the same grunt, give or take, they have said the boxes hold up. IF it does pop, the PPG dog set will go in. Ratios to die for.
I'm surprised to hear that the getrag is up for the task
MAY not be, but if I be nice to it, it may last a few years, I which time I can save for what will eventually go into it.
Car has only done 3 kms this year. Need to get back to driving it :(.
Just saying, go sequential, you won't look back :)
PPGs are strong, how strong is a different matter, the BSM car went through a few of em to while they still had restrictors in limiting power to about 300rwkw, very torquey motor though
And for what it is going to cost to set up the Getrag your not far off the OS88
