My JB that I had rebuilt recently is softer than the old one, my Starlet clutch feels heavier.
Oh and after putting my big tyres on the back i'm cruising under 3000rpm :) The longer legs are awesome, I actually get boost in first gear now!
So, I went for a drive in Bobby's R34 this arvo. My mind is made up, the OS88 is one amazing bit of kit. There is a bit of a clunk between gears while doodling around which isn't a huge deal. When up it, its very smooth and effortless. I was so surprised at how user friendly it was. I jumped in the drivers seat and played with the clutch - that is NOT how I remember Steveo's OS R3C. Its actually lighter than my Nismo coppermix. It must have something to do with the OS fork which you can buy with the OS88. Yep... that's all I can say lol.
  • Like 1
I have a TS3B which is very driveable while I know people with a R3C that are very jerky.
They are cheaper as well and can handle decent power, I just snapped an input shaft with over 700hp and it hasn't skipped a beat.
I just checked and they come with a Hollinger 26 spline option as well :)
For Micky Hill
265 / 35 x 18 tyre
8000 RPM limit
3.545 diff gears
Optional Ratio 2 : 1st: 2.890 / 2nd: 1.981 / 3rd: 1.468 / 4th: 1.174 / 5th: 1.00 / 6th: 0.757 < - - those ratios
1 = 94 km/h
2 = 137 km/h
3 = 185 km/h
4 = 231 km/h
5 = 272 km/h
6 = 359 km/h
Sounds a little tall!
http://www.nismo.co.jp/omori_factory/original_menu/final_g/index.html
Nismo 3.916 final drive. Don't look at the price :D
Same ratios with the 3.916. Ohhh baby :D
1 = 85 km/h
2 = 124 km/h
3 = 168 km/h
4 = 210 km/h
5 = 246 km/h
6 = 325 km/h
WHAT IN THE HELL.. you could buy like 3 diffs for that money
For Micky Hill
265 / 35 x 18 tyre
8000 RPM limit
3.545 diff gears
1 = 94 km/h
2 = 137 km/h
3 = 185 km/h
4 = 231 km/h
5 = 272 km/h
6 = 359 km/h
1 = 85 km/h
2 = 124 km/h
3 = 168 km/h
4 = 210 km/h
5 = 246 km/h
6 = 325 km/h
fek me!
For Micky Hill
265 / 35 x 18 tyre
8000 RPM limit
3.545 diff gears
1 = 94 km/h
2 = 137 km/h
3 = 185 km/h
4 = 231 km/h
5 = 272 km/h
6 = 359 km/h
1 = 85 km/h
2 = 124 km/h
3 = 168 km/h
4 = 210 km/h
5 = 246 km/h
6 = 325 km/h
final drive r33 is 4.11 not 3.56 unless u have r34 gtr diffs
No way. It's Nismo. Can't be :P
Like the Nismo cough Toyota cough fuel pump lol
He's talking about my R34 with 3.545s
And to rub salt in, they are probably just standard gears from some 4wd van or something lol
I know the 3.9s are available in a auto rear wheel drive R200 diff from some thing just can't for the life of me remember what, we looked in to it for the BSM car while it was still in IP
For Micky Hill
265 / 35 x 18 tyre
8000 RPM limit
3.545 diff gears
1 = 94 km/h
2 = 137 km/h
3 = 185 km/h
4 = 231 km/h
5 = 272 km/h
6 = 359 km/h
1 = 85 km/h
2 = 124 km/h
3 = 168 km/h
4 = 210 km/h
5 = 246 km/h
6 = 325 km/h
Thanks for that, a bit tall I thinks, may have to put one of the 4.11 sets I have in it, which is good cause now I can just drop the spare R32 rear diff ( late model big shaft one ) straight in :)
For shits and giggles do it with 275/35/19s lol
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
