I'm liking the Option 2 ratios. Can always go to 4.375 diffs if needed.
Should have come past my place Paul...would have liked to see the OS88 first hand.
Weren't in it long, Charlie. I didn't want to start inviting half of SAU when Bob went well and truly out of his way already.
As I said, very very impressed. Slick, quick, effortless, quiet and no fuss.
Bob even slowed down and stopped at a set of lights in 4th gear. He clutched in and pushed the lever up and selected 1st. No noise, nothing. Let the clutch out and away we went.
Bobcat has bought some aftermarket shifter but it's not completed yet. He just simply clutched in and pulled the lever, next gear and away we go!
When Marcus got a quote for me, the guy that did my head suggested/recommended the OS88 straight away, $$$ being the problem. The issue is, as BigMicky said earlier, the standard casing only allows so much physical gear size, limiting strength.
I know I'm repeating myself but the level of street ability and user friendliness surprised me. I thought it would have been as agricultural as a John Deer tractor.
Now the question is
Is the 88 cheaper than an H6S?
...hang on...do hollinger still do the gtr spec boxes? I have a funny feeling they do not
Albins do one now and even Modena have a sequential that would accept the transfer case. Plus the new Quaife. Plenty of options... None a bargain.
From what Bob was saying, the holinger doesn't like more than 800 HP (not saying I'm at 800 HP). It's also straight cut.
Quaife - 750 hp
Modena - not sure
Albins - straight cut
Being a "street" car, I don't want to wear ear plugs while driving the damn thing. That's not what it's about.
It doesn't matter what way I/we go, none of the options are cheap. Even the cheapest option of the PPG 1-4 helical dog set will be the best bit of $7,000 by the time it's all done.
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
