This would speed up the process ;)
Rightio.
I've been offered $19 K with a working head that has V cam. If it's not sold on here it will go to this certain guy, he just can't do it at the moment. So I'm not fussed if it doesn't move.
Might sound like a lot but
GT block - two on here for sale for $10k
Stroker - another $7k
Head cost me $11k
Marcus also sold his engine that was very similar just in a N1 block for $18K iirc two weeks ago.
Rightio.
Head cost me $11k
ah so Marcus finally sold his engine
Almost took him a year
Also yeah that's a lot Paul :D
Rightio.
Head cost me $11k
Try build it for that price though, good luck!
I bet your motor probably cost as much and you got stock crank, stock springs & lower than factory compression ratio and blowy poncams ;) Edited by Mick_o
Nup. My motor cost a LOT less than that lol.
Rightio.
Head cost me $11k
Paul it went for a fair bit more than that plus a stock engine and all gear to turn my car back to stock.
Wasn't advertised, just word of mouth and went to very appreciative owner.
What people don't get is that to get the sort of responsive power that Pauls engine has costs $$$ and time.
Anyone can build a peak power engine but to build one that gives you that nice big fat torque hit sorts the real engine builders out from the wannabees. Straight line grunt, pfft...you want a drivers car that gives race engine performance every time the loud pedal gets touched and will do it all day long.
You can bang your head all day arguing the point but proof is best kept to actual bum in seat feel but all passengers must wear a nappy as you'll soon get sick of cleaning shit stains off the passenger seat.
What Paul's planning now will be a very special and unique package and engines like these are far and few between because there are no short cuts, plain and simple they cost $$$, a lot of time and frustration.
  • Like 1
this ^ has now got me intrigued
Im gonna guess and say that he's going for RB 3.5, with GTX2863r with -5 comp housings, OS88 tranny in an R34 GTR
Yeah the next package will be pure insanity and super special i cant wait!
I can tell you from the drivers seat that the 2.8L is absolutely insane it free revs like an roadbike engine! A tiny blip on the throttle and the needle shoots off to redline as quick as you can blink! In any gear from 2nd gear and 4000rpm HANG THE f**k ON to that steering wheel as shit around you gets blurry and things start coming up REALLY fast!
Ive been in all kinds of wound up stock 2.6s and nothing is remotely as ferocious as this thing is! If you think that your 500kw 2.6L will touch this car you're dreaming as it just makes grunt like nothing I've ever experienced its sad to see it go as it really is a rare engine and theres definitely not another engine around like this thing.
  • Like 1
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
