Who gives a turd. They're such a better looking car.
Thats what I love about you, so open minded, lol
Keep the car away from the paint shop, they held it hostage for 18 months last time :ph34r2: :ph34r2:
Gearbox goes out on Wednesday.
Turns out the baskets collapsed in the top of the injector. Seems to be a pretty big issue with 2000's.
New (different style) baskets in and it runs like a Swiss watch.
They have been flowed back up. All spot on. I'll take some photos and explain what's happening on Wedneaday night.
Joeys got flowed up and had the same issue but not as bad.
So I picked the car up today after being in a panel shop for 18 months. Car ran beautiful for 500M and had a fit. Had to get it towed. Wouldn't even start! Micky Hill came to the rescue and we towed it to Unigroup. Thanks a lot mate!
No worries, glad to help out
Also glad to see you putting the box in it and enjoying it for awhile, I even think you will beat me at this point as I am waiting for a few things to come though
Bit of an update.
The 5 speed should be out of it today. I dropped out transfer case oil, gearbox oil, coolant, engine oil and 60 L of fresh E85 so the guys can run it up to make sure it's all happy days. As much as I hate paying for them to change the oil it's just too much of a hassle to do it while it's out there. The guys also did me a huge favour to open up the workshop at 6 PM on Sunday to take it in. The quicker it's out the better.
I picked up a modified transfer case from Award today. I asked Terry how much difference there is between a stock one and this, his reply was "heaps". Should be interesting.
It also looks like atleast my primary 044 has kicked the bucket again! It got started last night from dead cold, AFR's were 15.8-16.2 and from memory the fuel pressure was a tad low. Just above 2.1 ish bar at idle, I remember it sitting a bit above 2.5.I've had this issue before and turned out to be a lazy fuel pump. Grrrrr. Time for one big single pump I think. Suggestions?
Progress shots should filter through tomorrow.
it will help if you clearance a little of the tinwork around the reverse lockout fitting on the LHS of the box as it gets very close to the body. Alternatively, just leave it out and get rid of the whole reverse lockout mechanism. Just need to plug up the whole with the right bolt/fitting ;)
Something like this Paul? http://www.aftermarketindustries.com.au/fuel-pumps--accessories-c3/holley-dominator-1800-p92/
I know its technically 2 pumps in one but at least its rated for e85 and wont die. Plus you can still run it staged like your current setup to keep the fuel cool.
It's the same one I have going in :)
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
