it will help if you clearance a little of the tinwork around the reverse lockout fitting on the LHS of the box as it gets very close to the body. Alternatively, just leave it out and get rid of the whole reverse lockout mechanism. Just need to plug up the whole with the right bolt/fitting ;)
I'm heading out there today. I'll see how they're going. :D
Found this on the LS1 forum:
80-holley_pump_specs_947b5fa4b06a2958c97
http://ls1tech.com/forums/fueling-injection/1792075-max-power-holley-12-1800-a-2.html
Set your base pressure at 43, boost to 30. Flow at the pump will be abouyt 125Gph = 473lt/h = 7.8lt/min.
987A01E1-CE10-4B19-B99B-B682678D1092_zps
1B755DD4-9B0F-4D1B-8779-A44C2076EB34_zps
There is the culprit. The tooth fairy was good, bought me a OS88 instead of a few bucks. Winner!
7A8A23C5-9D2E-4992-9B21-E1DC96C56CC1_zps
A6C4A850-FEB2-43E2-8502-C7AD55D7DAC6_zps
E06771C5-2FB5-49CC-B08E-2AFC66733CAF_zps
R3C
C188B285-6593-41EE-B9BE-E06C3CF3493B_zps
Old and new. Evidence of an exhaust leak on the 5 speed.
9ABF37B3-9592-4A69-8672-8C52A913B821_zps
Modified transfer case.
  • Like 2
Both Nitto 1 and its OS88, and one other R34 that ran a Hollinger up here in Cairns used a custom spec NPC twin plate, setup to handle over 1100hp. Basically what I have in my car, with a different type of spring hub centre. So when you get tired of it, you know where to go. Price was reasonable too.$2920.
Day of nothing yesterday. A sub station up the road went up in smoke and the whale was up on the hoist higher than the gearbox jack could reach. Lol.
Took back my old transfer case to Award as it was on exchange basis. Awesome guys at Award, Trish and Terry. Highly recommended!!
That was that.
Looking at fuel pumps, I found this bad boy.
http://fuelab.com/products/race/prodigy-fuel-pumps/item/42402_prodigy_fuel_pump_high_power_efi_in_line/
720L/hour at 3 bar and 560 ish at 75 psi. I'm sick of dicking around with 044's that just don't last. It will also cover me for any future turbo changes/upgrades... *cough* :D. It's E85 friendly also.
That was that.
Pump looks the works, know anyone that have used them ?
Glad to see you are looking ahead, if you decided to change your turbo, what do you have in mind. I thought your car was pretty well balanced as it is but maybe a new age Turbo could make it even better :)
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
