Yeah, Wiggins. 5 in total. Blown cooler pipes are no longer (unless the plenum one pops). No more taking front bars off!
Thinking about painting the airbox black, cutting a hole in the top of it and using the factory airbox snorkel to feed the box too. Can't hurt!?
Silicone is good for 40 psi or so, you will be fine !
Looking GOOD brother!
I like how they ran your piping. Mine is out to the side to make room for the PS reservoir and such, but I like yours a lot. Hypertune is top-notch stuff! I am always leary of 100% solid connections to the coolers because it seems they might induce stress on the piping and turbo manifolds when the engine torques around, but they don't have anything that looks as sexy as that to be honest!
http://youtu.be/76CEWVXru3M
Have a look. They move around quite a fair bit. More than enough when all combined I'd say. :)
My fabricator is trying to talk me out of going aluminium piping, those pics just about sealed the deal for me :) looks great. I'll need to do some reading on these so called Wiggins clamps
There isn't much you need to know, they are bright purple and very racecar. Just open up your wallet and prepare for butthurt when you hear the price.
On topic, I cannot wait for this to be done. The EFR looks very at home in there that's for sure.
Adel Wiggins clamps. They're actually aviation gear but can be used in automotive applications also. They're a bit of a homo colour but they're that colour so plane guys can see them.
Make sure you're sitting down when you see the price.
What's wrong with alloy piping? Does he want to use stainless?
Yeah we use them at work (I work in an aviation environment) and they are used for everything. If they can handle bleed air straight from a turbine compressor (80+ psi and a couple of hundred degrees Celsius) then they should stop a cooler pipe coming off ;)
You should ask about having them lockwired piggaz. Just for some extra security/piece of mind.
Lock wired is a bit too much. I really can't see these blowing off with 30-35 psi considering they're rated to 150-200 psi or something. If they do then there would be another issue like a busted engine mount.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
