Why couldn't they have just moved from the VL to the XR6 turbo and be happy with them.
venetians and remove front shafts. then 2 speed powerglide.
Because you are not Lebanese?
Oh I went there.
Ha ha ha. You guys.
Funny
On this topic, just a question, aren't the guys in Queensland still the record holders for the fastest GTR with 4wd, a 26, and H pattern? 7s from memory.
Don't get me wrong I love an angry Rb big cams, laggy single and a H pattern box doing 9's.
This smoothed engine bays and auto conversions not so much.
Me too. Just have no love for the 2wd auto conversion. Just get a normal skyline or falcommodore if you want to do that. Edited by XGTRX
The auto conversions are still 4WD, each to their own, I don't mind dragging to see what improvement the latest mods have made and for some shits and giggles but track is life
Come on Piggy get this thing finished already, there are tracks that need tearing up
data:image/gif;base64,R0lGODlhCAAKAIABAAAAAP///yH5BAEAAAEALAAAAAAIAAoAAAISTIBmoLy9XDqyxktfkuo05AQFADs= image.jpeg
Saw this run 10s today, vnice 34!
  • 2 months later...
Time for an update.
due to time constraints and the ever looming beer bottle, the car got taken to Grim Performance at Hornsby to get the exhaust done amongst a whole heap of other stuff.
- Exhaust completed.
- Individual EGT on manifold.
- Post turbine EGT
- Exhaust gas pressure sensor
- Pressure and temp pre and post compressor.
- Rear subframe has been out. All bushes have been replaced including diff bushes.
- Nismo GT Pro diff has been turned down to soft. Cranky unit!
- New steering race has gone in. Car slipped off a jack and busted a nob off.
To be done.
- Install and plumb fuel system with -10 Teflon braid lines.
- ECU change. Blackbox is gone, Emtron KV8 going in.
- Airbox.
- Strain gauge for sequential.
- Install V cam.
- Tune.
Ive had the Step 2 264 at 8.7 mm cam (WTF am I gonna do with a fairy penguin 8.7mm of lift) reground to something that's a bit more aggressive. Not sure of the exact grind yet but I will know soon enough. Something around 265-270 with 10.2-10.4 mm of lift.
A16A99FC-0DAF-4D17-873F-118EB0AF9872_zps
Dump pipe.
087CB4AE-9EB9-4E77-A349-4159252E74C3_zps
Mid muffler section.
33081E8A-151A-4BB5-A9BC-2BEC30E3F232_zps
Rear diff section.
675DB7AA-9981-4C63-A02C-EFC6E17DB3B8_zps
Gate merge. This photo looks funny. The merge looks very sharp but it isn't really. Must be the lighting.
6BC357F7-2A02-4F89-B59C-C8846866E33C_zps
DEE3FA94-F578-4007-BC00-40C077AE5891_zps
  • Like 7
Reason for this?
Will it chirp second?
I said jokingly "is there anything else you'd like to measure."
that was the answer. It's all got to do with measuring what the turbo is doing.
58 minutes ago, Piggaz said:
To be done.
- Airbox.
- Install V cam.
- Tune.
Getting the notification that this thread had new posts feels like a fun and rare experience now, funny as I've probably been following it for YEARS and Piggaz was a nameless face that I'd never seen in Ozziland.  Now it's a car and a person I know and there is more appreciation for the epic research, thought, development, alcohol consumed, hangovers, work, BBQs and alcohol consumed involved in getting it to this stage that it's particularly exciting seeing it get to this stage.  Very excited to see it getting near being ready to run again!
PS.  You shouldn't ask questions you may regret if they're answered :P
  • Like 2
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
