52 minutes ago, r32-25t said:
This all started cause a gearbox broke,
I think it was actually 4 but that's in the past and right now if I want to drive mine I go to the garage and turn the key :)
And when yours wasn't running, I could have wandered out the back, pushed the boat out and rip skidz too. Your car was off the road for a similar time wasn't it? ?
The car was pulled off the road running. I could have whacked a stock box in it, replace the turbo and it would have running within a couple weeks.
Can't remember it was a few years though  was about the same time you broke your engine I think
3 minutes ago, ActionDan said:
Ok ladies simmer down.
Time to start taking bets on the power figure.
Apparently 480 AWKW was the most power out of a 8374 awkw (out of an Evo) Scott has seen on his dyno.
Nick (3.0/8374) went 461, 24 psi
Pete (3.2/vcam/8374) went 457awkw, 25 psi tapering back to 21 psi (120,000 turbine speed).
I don't know. It's all dictated by that magic 127,000 RPM turbine speed. What will be more interesting will be the boost level that it'll need to get there. Going off the -5 setup, it went 441 at 19 psi. Realistically, I should have just left it there.  Boost level I'm gonna peg at no more then 25 psi, tapering back down.
i know another evo making 450kw 8374 .92 internal gate at 36 psi
why stop at 25 psi
why stop at 25 psi
Because of turbine speed.
127k max. If it reaches that, the turbo is done, irrespective of pressure.
Its no secret that these things have certain parameters to keep within, just like any mechanical part.
What speed are you at with your 30 or 32 psi?
and you know 25 = 127k?
is it to keep them alive or are you saying it wont anymore power beyond 127k
i was about to turn mine up to 34psi haha
No I don't know 25 psi will equal 127K. It was an educated guess... I could be well off. We will know because the speed sensor will be going back to the ecu.
Hopefully the wheel doesn't end up out the back of the exhaust. You're bloody crazy to turn it up that much without knowing what it's spinning at. Not the turbo's fault it if fails.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
