And I'm still waiting to be proven wrong, cause every time someone fits longer duration cams the bottom end power drops, which is tested very easily by doing a before and after compression test
so until the dynamic compression then increases again at their higher rpm efficiency level they will always be left behind in the bottom end
  • Like 1
I think that is the point I've always made - I don't recall anyone ever saying longer duration cams pick up torque at the bottom, be interesting to see if you have any reference or if you are just winning a debate against a made up side :)      If you can make the compromise (read: less VE) in a part of the rev range you aren't using then you just use the part where your VE (or "dynamic compression" as you're saying) starts building beyond what the smaller cams can provide, then you are always winning.   You wouldn't use 288s and a Promod94 Precision for a GTR used for hill climbs, you wouldn't use 256s and a pair of -9s for Pro-class in WTAC and you wouldn't use VCam and an EFR9174 for Pro-GTR drag racing.
I'm not saying bigger cams don't have their place, if want a 1000hp at the wheels then obviously you're going to use a fairly decent sized cam but then again at those levels response isn't at the forefront of your priorities.
What im saying is so many people are fitting bigger cams in the pursuit of better down low power and improved response, perfect expample is If you have an engine that has cams that still make power at 8500 and turbos that roll over at 7000 how is bigger cams going to be a benefit?
My findings come from many cars I have worked on from 6L na v8, 2.0 4cly turbos and down to 1.3L 4cly na engines. Even rotarys with their port timing will do exactly the same thing
Exactly.  Sounds a bit like you're arguing with yourself and declaring yourself the winner :D  The setup needs to match the other parts, most would agree.    I'm not aware of anyone fitting larger cams for low down power, though improved response within the target rev range... perhaps.
  • Like 1
2 minutes ago, ActionDan said:
Take it back to the cam thread.
I'll post in there next week when my setup is 4000rpm laggier for the extra 10 peak kW;)
OOPS!  Good call ActionDan, sorry Piggy.  If anything we should be talking about your low emissions cams and big laggy lightswitch turbo! ;)
Yes, that'd be appreciated in the correct forum :D
Couldn't fit the emission friendly cam in this time round. It's all in its box in the garage. Tackle that later on.
Lightswitch, laggy, snappy, unresponsive, slow to react to throttle input single is a goer but ?.
  • Like 4
4 hours ago, Piggaz said:
260 poncam strikes again ?.
What sort of grind did you decide on with Kelford? Lift at 50 thou (or 1 mm) and lift? Can understand if you don't want to release that info though ?.
Considered pulling the head off to relieve it and run more lift with a not so long duration?
The Kelford split cams (182S) I had in were 10.8mm lift so the head had to be releaved already.
New ones are as follows "We’ve just run some numbers and we can take our L182-A 260° spec and turn it into a 260° advertised (measured at 0.1mm valve lift with lash set), 226° @ 1mm valve lift and would be .406” cam lift, coming out at 10.00mm valve lift on the intake and 9.95mm valve lift on the exhaust after lash. At the base circle we’d need to cut them to, to try and ease the re-shimming process, you’ll be right on our safety limits of velocity and getting close to our nose radius limit, it’d be an aggressive wee monster and something I think would be a much better fit for your setup given your historic results."
There was an option to also drop to a 262 advertised with a 222 at 1mm and drop valve lift to 9.7mm but decided against it as they recommended the other grind
Edited by SimonR32
  • Like 1
11 minutes ago, SimonR32 said:
It's ready to go, just needs a tune... Tuner has been on holidays for a few weeks so waiting until he gets back and into it
Race you! I dropped my modified Cam off yesterday.
8 minutes ago, Sub Boy32 said:
Are we there yet....are we there yet....are we there yet?!?!?
Haven't heard anything. Not gonna be a pest and ask 4 times a day where they're upto.
  • Like 1
That's how a particular workshop tunes actually  (not the one your car is at).
    • And at over $2 per litre I'm starting to consider setting up a corn mash still and converting over to alcohol and running mine on it !  Up side of that is it all doesn't have to go into the car ! Win win !
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
