I know there was a situation that made it difficult to start your work , I know you do not like to rush work, I understand that you are a patient man, I am sure you do not want to be a pest to the builder, you are also happy to be able to put some more $s together and these are all qualities I would love to posses , but my background of having work done on  my car has killed all of your fine qualities :(
SO
Any update for everyone :91_thumbsup:
Ya'll African Americans honestly think he would "forget" to update the thread if there was a noteworthy update?
I hope he sits on the final figure for ages and just posts a teaser vid of him driving it out of the shop or something.
Having tuners/mechanics work on my cars has been an eye opener for me, I am much more patient now.
I paid an invoice for some work done two Fridays ago. Does that count? ?
The sensor wiring loom was completed. Hardly worth making a fuss over.
The guy that's looking after it works 3 days a week. So it's getting 3 days a week of work done on it. I would say by the end of this week all wiring (box, MAC valves, ecu, fuel system and sensors) will be done. Then it's just tuning.
Atleast it's been started. ☺️
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
