For anyone else playing along re timing issue.
A good unbiased thread here.
Unsurprisingly issues occurs on a number of ECUs, not limited to Haltech, and even features our OP(and others) claiming the same issue on a PowerFC, madness...
Seems like most ECU manufacturers and Tuners were aware of and had produces solutions to address it, including modified/better CAS discs, crank triggers, etc.
Too much was said for me to not look into it as a precaution - So thanks for that even if your caps are flat.
I am probably as far from a flat clapper as you can get!
Yes it is an issue with not just Haltech, motec m800 and earlier, link etc all suffer from it.
With a good CAS and good signal wires PFC, Nistune and Adaptronic won't suffer from it, if you get really bored you can listen to a youtube video or post Andy from Adaptronic made about it too. So for a plug in ECU designed for that engine I think it's a rubbish ECU choice if you need to fit aftermarket sensors.
It's always to learn something new :D
Haltech "claim" not an issue with Platinum Pro, but was a problem on earlier ECUs, guess I'll find out it ever happens.
So I guess the bombshell here is old shit can be problematic... but new shit has less issues.. Who knew!
LOL it's defiantly a problem with the Platinum pro, even worse with the Elite range but I won't tag Jono Pace in this thread for him to rage about them.
Don't always believe the marking bullshit that comes from a manufacturer, i am sure you tuner would have tuned you car extremely safe up top if it was showing any issues.
Just now, ActionDan said:
He might have given me an ear bashing on FB about it already?
Wonder why my car hasn't seen it. Maybe the key is don't drive it.
it may well have it, you can tune around it to a degree or just ignore it like most do.
That must be it then, I can't there being any possibility that it's just working properly.
I'll be ready to replace the ECU when I put my TH400 in.
Just put a crank trigger kit on it!
You will need it for the 1000hp and your TH400
  • Like 1
Setup a real crank trigger.
Throw OEM CAS disc in the bin. Fit an aftermarket disc.
Run whatever ECU you want or as many Haltech products as your passenger footwell can fit. Job done.
  • Like 2
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
