For anyone else playing along re timing issue.
A good unbiased thread here.
Unsurprisingly issues occurs on a number of ECUs, not limited to Haltech, and even features our OP(and others) claiming the same issue on a PowerFC, madness...
Seems like most ECU manufacturers and Tuners were aware of and had produces solutions to address it, including modified/better CAS discs, crank triggers, etc.
Too much was said for me to not look into it as a precaution - So thanks for that even if your caps are flat.
I am probably as far from a flat clapper as you can get!
Yes it is an issue with not just Haltech, motec m800 and earlier, link etc all suffer from it.
With a good CAS and good signal wires PFC, Nistune and Adaptronic won't suffer from it, if you get really bored you can listen to a youtube video or post Andy from Adaptronic made about it too. So for a plug in ECU designed for that engine I think it's a rubbish ECU choice if you need to fit aftermarket sensors.
It's always to learn something new :D
Haltech "claim" not an issue with Platinum Pro, but was a problem on earlier ECUs, guess I'll find out it ever happens.
So I guess the bombshell here is old shit can be problematic... but new shit has less issues.. Who knew!
LOL it's defiantly a problem with the Platinum pro, even worse with the Elite range but I won't tag Jono Pace in this thread for him to rage about them.
Don't always believe the marking bullshit that comes from a manufacturer, i am sure you tuner would have tuned you car extremely safe up top if it was showing any issues.
Just now, ActionDan said:
He might have given me an ear bashing on FB about it already?
Wonder why my car hasn't seen it. Maybe the key is don't drive it.
it may well have it, you can tune around it to a degree or just ignore it like most do.
That must be it then, I can't there being any possibility that it's just working properly.
I'll be ready to replace the ECU when I put my TH400 in.
Just put a crank trigger kit on it!
You will need it for the 1000hp and your TH400
  • Like 1
Setup a real crank trigger.
Throw OEM CAS disc in the bin. Fit an aftermarket disc.
Run whatever ECU you want or as many Haltech products as your passenger footwell can fit. Job done.
  • Like 2
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
