14 minutes ago, Piggaz said:
Well, guys get all excited about a billet wheel being lighter.... but most of the weight is in the turbine wheel. The efr wheel is half the weight of a normal inconel wheel.
Removal of all the small piping and super tight bends of the intake and exhaust. Just look at it all, it's hardly designed for MASS airflow. Put a pressure sensor on the intake of a 450 kw gtr and I bet it's pulling bulk vacuum. Dyson would be impressed.
Haha, Piglets rebuild of his busted Dyson :D
34 minutes ago, ActionDan said:
I wonder why BMW went with all the hassle of twins on a straight 6 motor instead of a slightly larger single?
I guess they wanted to make it laggier. I mean, 1400 rpm is pretty shit response - A single would be on idle for sure.
I bet a cheeseburger that their packaging is not a spitting image of the RB26 configuration.  A huge amount of my argument against low mount twins in a GTR when any kind of flow is needed has to do with the packaging.
Edited by Lithium
Yep 100% you can't get a bigger exhaust housing on to those stock manifolds and the rear intake in rubbish.
Would like to see some low mounted EFR's on customer manifolds.
"When any kind of flow is needed" means different things to different people.
I think you guys need to go back and read some of your own posts from 10yrs ago on here and see how you were reacting to 300-350rwkw back in the day.
For those power levels, even today, twins are fine for a mildly driven street car. Does that mean there are not better solutions? Of course not, it's been a decade of tech advancement, but the argument seems to boil down to "did you know that if you spend more time and money you will get a better result?!".
No shit lol
Edited by ActionDan
  • Like 1
Artec do a 0.85 T28 ass.
4 hours ago, Lithium said:
9180 would do for now :D
Hows that build of yours going?
Sick f**king work Piggy, looking forward to seeing the final result - but you're already smashing it. Can't wait for the data, and for you to finally be able to get out there and do awesome shit with it.  I remember the OTP discussion we had back in 2013 where you were challenging me to think of any RB setup with response and power like your own, bet you wouldn't have expected your own car to end up with a single turbo on the exact same engine and as a result stand up harder earlier than it ever did before? :D
f**king kudos to having the Insight involved to get a great thing even better.
Honorary mention gotta go to the drunken conversations with the Wild the sphincter of the universe Rare Breed.
* This post sponsored by the SAU language filter
Slowly getting there. Wiring was completed last week so a little more fab then it can get some fluids and a tune :)
  • Like 1
I'm curious what spark plug gaps you are running with the Godzilla motorsport kit?
I might need new coilpacks and was thinking this kit over the conventional splitfires.
In the search your the only guy i saw that runs the Godzilla R35 billet coil pack kit, so curious on your opinion on why you went these over spitfires.
I'll have to get back to you on that. Some plug that Scott uses. It's a heat range 9 with a funny tip. I thought I took a photo but I can't find it.
Actually i just saw this in a comments Facebook section of the Godzilla Motorsport page which to me was interesting.
So i spose its just for cars to run high power reliably without a breakdown in spark. Rather than what i thought of larger gap better bang/performance
Bruce Sullivan What plug gap can you run with these ? Can you get away with 1.1 for around the 450AWKW's ?
Cheers
LikeShow more reactions
 · Reply · May 28, 2016 at 7:43pm
Remove
Godzilla Motorsport
Godzilla Motorsport No turbo engine should ever run 1.1mm gap . That is only for na engines
 · Reply · May 30, 2016 at 5:52pm
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
