Piglet's Rebuild Of His Busted Tomei 2.8
28 minutes ago, r32-25t said:
Oh and a t51r mod ?
If I wanted to listen to a busted pelicans ass I’d go down to the local boat ramp and feed the things. One great way to ruin a car is listening to that dribble!
On 05/01/2018 at 1:37 PM, Piggaz said:
Hasn’t moved in 6 weeks.
Should get onto that.
How Long is the gearbag away?
Leaving SA today, so hopefully late this week/early next week... Or if it's with Australia Post sometime in 2019
You should have bought the car over on the weekend, fatz and myself De - lebbed a GT-R, replaced an entire fuel system and fitted a T04z kit.
While drinking 5 slabs of beer, two bottles of rum, one bottle of makers mark.
*with a little bit of extra help from some other SAU lads*.
Could gave smashed out a gearbox swap too
Sounds like these kents might actually be able to keep up with us pigman!
There is no way I’m taking th fat man on in a beer for beer challenge.
Death is certain.
10 minutes ago, BakemonoRicer said:
.....hmmmm not sure if they can keep up with the corona king though.....
i still have the record for the most 'rona's drunk at an efr BBQ :cool:
You have the record because no one else will drink that watered down cats piss.
  • Like 2
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
