After speaking to Terry at award, he said for the love of god, use a sprung centre. It doesn't matter what box you have behind it, a bit of give in the driveline goes along way.
Exedy is dreadful, based on running a twin plate in past - yuk
pretty much more brutal than my os giken triple plate & that is saying something
ive never driven a coppermix but that will change when you're back on the road :)
That surprises me, I have the Exedy twin in my 32 and the triple in my 34 and find both very very easy to drive, the triple is a bit noisy though
Paul, what happened to the email you where sending me about payment for said boxes ?
11.5 ;)
29th of October last year. All good.
But yeah, I'm itching to get it out.
cant believe you just didn't wack on standard box in the meantime and use the car
Question......all the E85 in the sperm whale would be totally wasted am I right and battery included too?
I had a box sitting in the garage since Australia Day. It. Never made it in the car because it's been sitting at my mates workshop getting the boot seam welded and shit. I won't bother putting it in now lol.
I made sure there was no ethanol in the tank. Drove around diluting it until it was E0. The battery have been on trickle charge in the workshop :)
Personally, I would be have written correspondence from OS-Giken confirming what clutch you should or shouldn't run. A friend was one of the first to run one in his car and when it went pop they OS Giken Japan blamed the sprung clutch. IIFC his was a dog sequential not helical so may make the difference between being open to using a sprung centre if you are going helical
What broke exactly ?
Would you happen to have details of car, ie power, capacity etc
This troubles me, if I'm forking out this kind of coin on a box I really don't want to hear they are breaking unless it was on some massive monster of a car
The ones we are looking at are dog engagement helical cut sequentials with straight cut reverse
I have also long suspected sprung centers have no place in high powered car or need to have stronger springs so they don't bind
That's a very valid point, Pete.
Maybe just throw a R3C at it and be done with it.
Also, Brett pointed out that the OS88 is a push type setup. Which means that my pull type coppermix wouldn't have worked anyway.
What a cock in the bum hole!
  • 3 weeks later...
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
