  On 05/08/2015 at 12:41 PM, NXTIME said:
it will help if you clearance a little of the tinwork around the reverse lockout fitting on the LHS of the box as it gets very close to the body. Alternatively, just leave it out and get rid of the whole reverse lockout mechanism. Just need to plug up the whole with the right bolt/fitting ;)
I'm heading out there today. I'll see how they're going. :D
Found this on the LS1 forum:
80-holley_pump_specs_947b5fa4b06a2958c97
http://ls1tech.com/forums/fueling-injection/1792075-max-power-holley-12-1800-a-2.html
Set your base pressure at 43, boost to 30. Flow at the pump will be abouyt 125Gph = 473lt/h = 7.8lt/min.
987A01E1-CE10-4B19-B99B-B682678D1092_zps
1B755DD4-9B0F-4D1B-8779-A44C2076EB34_zps
There is the culprit. The tooth fairy was good, bought me a OS88 instead of a few bucks. Winner!
7A8A23C5-9D2E-4992-9B21-E1DC96C56CC1_zps
A6C4A850-FEB2-43E2-8502-C7AD55D7DAC6_zps
E06771C5-2FB5-49CC-B08E-2AFC66733CAF_zps
R3C
C188B285-6593-41EE-B9BE-E06C3CF3493B_zps
Old and new. Evidence of an exhaust leak on the 5 speed.
9ABF37B3-9592-4A69-8672-8C52A913B821_zps
Modified transfer case.
  • Like 2
Both Nitto 1 and its OS88, and one other R34 that ran a Hollinger up here in Cairns used a custom spec NPC twin plate, setup to handle over 1100hp. Basically what I have in my car, with a different type of spring hub centre. So when you get tired of it, you know where to go. Price was reasonable too.$2920.
Day of nothing yesterday. A sub station up the road went up in smoke and the whale was up on the hoist higher than the gearbox jack could reach. Lol.
Took back my old transfer case to Award as it was on exchange basis. Awesome guys at Award, Trish and Terry. Highly recommended!!
That was that.
Looking at fuel pumps, I found this bad boy.
http://fuelab.com/products/race/prodigy-fuel-pumps/item/42402_prodigy_fuel_pump_high_power_efi_in_line/
720L/hour at 3 bar and 560 ish at 75 psi. I'm sick of dicking around with 044's that just don't last. It will also cover me for any future turbo changes/upgrades... *cough* :D. It's E85 friendly also.
That was that.
Pump looks the works, know anyone that have used them ?
Glad to see you are looking ahead, if you decided to change your turbo, what do you have in mind. I thought your car was pretty well balanced as it is but maybe a new age Turbo could make it even better :)
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
