Man I'm honestly thinking about getting it. What are your thoughts? Mine is a weekend warrior...and it's apparently not much more money than an R34 conversion.
What parts came with it? What else is needed? Will my nismo super coppermix twin plate clutch work or do I HAVE to swap to the OS giken unit?
Also do you need to run your stock transfer case or do they include one?
I think we are going to be similar power levels.
AWESOME video car looks super fun.
It definitely changes the car from the tall geared OS 5 speed that I had in it. "Woke it up" as such.
You don't need to run the OS clutches, but it takes out one less headache when putting it all together. I looked into trying to salvage the coppermix as they really are THE clutch to have in a road going GTR. (Mine was in there since 2005 with no service/rebuild at all). It was all too hard. For starters the coppermix was a pull type, this box only has the bosses for a push type, then there was the bigger input shaft issue. The R3C is awesome, much better than expected and NOT how I remember the R3C in other cars I've driven. The pickup/friction point is quite low compared to the Coppermix which takes a bit of time to get used to. Apparently this is the new type. What they have changed, I'm not sure.
You will need to supply your own transfer case.
There are 4 gear options available. I went option 2. Assuming a 265/35x18 tyre and spinning to 8000 rpm each gear will go to
82
118
160
200
234 (same as stock as its 1:1)
310 (same as a factory 5 speed as its 0.757)
You're basically slotting an extra gear in before the 4th gear in a factory 5 speed box. If that makes sense.
With the box, I bought;
Box itself
Modified cross member
Bent shifter
Clutch
Release bearing
Clutch aligning tool
There is a bit of crashing and banging at low rpm, but that's just me not getting the timing 100%. I've only driven 60 kms or so with it so still very much a noob. Up high and drive it like its stolen, smooth as silk. Just slides into the next gear, you don't feel anything through the shifter. As quickly as you can pull back on the gear stick its in. I've found preloading the stick before you lift seems to work well too. I'm still clutching in ATM but as time goes on I'm sure I'll be able to do the no clutch/ lift throttle technique. I'm obviously not tuning a strain gauge - yet. I wouldn't like to daily drive it but for a weekend car it's great!
  • Like 1
Pretty much down the M4 and down Woodville Road at 6 ish PM. (I think you're a Sydney guy so you'll know what I'm talking about). It's all about timing. Going up is down a gear is tricky. The best way I have found is if you're in 4th basically stay in that gear till you come to the lights. As the revs drop to 1000 RPM just push the lever up a few times to either 1 or N depending on what the traffic is doing. No crunching or banging at all.
So much awesome
When you taking me for a spin
When I get this fuel system sorted. Not long after that video was taken it clogged the baskets up again. Full fuel system pull down required.
Damn that shit sucks man
You going to pull the tank out too or just flush it
The tank seems fine.
Not sure where it's coming from but it's fine enough to sneak through 23 micron filters.
6 micron filters are on order and changing ALL the lines. It's just not worth it.
Sounds like fun, as soon as you have driven it for a while the muscle memory will kick in.
This should shave a few seconds off your times :yes:
Nice legs :wub:
Fingers crossed that sorts it
Check the surge see if it's not the issue
I'm from Brisbane Qld, sorry for the question as I haven't read my os giken booklet. But once you engage reverse by pulling the lever up do you have to put the lever up again to go back to neutral or do you just push the lever down as you would when engage the next gears?
  • Like 1
