I saw PJ on Thursday. He said with the dollar the way it is he won't do them.
All good. As I mentioned earlier, there are another two sets between mates to use for fabrication. No drama.
That gate position issue isn't cool.
We go our Tial pair through VPW.
Hmm, i didnt check to see how close those 2 gates were on a 6boost manifold.
@ Buraz, What did you do to make them fit? (so i dont need to pull everything out to check)
Just clocked them around on the V band mount to clear each other?
Edited by GTRPSI
It's just a bitch to do anything really!! Just played around too much and wasted time. Best would have been to extend and separate them a bit. They basically lean on eachother, especially the hot side of one wastegate is leaning on the top of the other. Apparently it can be bad as it can damage the inside diaphragm. Yeh just clocked them around but it's not as easy as it sounds. As the v bands are in the way of eachother too.
Hard to explain but a pain in the arse.
So, had a delivery today. 1 gate only. :/.
I also noticed the send date on the package. One day after I asked for a refund. Funny that!. Came from NZ though.
Give me the other gate. Won't be dealing with them again!
I have no words Paulie other than tear someone's asshole up.
That's simply outright appalling
  • 1 month later...
A little bit of progress over Xmas.We will get there one day!
664B16D5-A6E9-4D53-AD0A-61AFB2982E1E_zps
Thats it's final orientation
9D449E54-3ECF-4A17-B7D0-9B235BBF57D0_zps
Housing to gasket size is atrocious. The manifold to gasket was pretty much spot on.
A26F0EEB-732A-4BCA-9246-141F52A77BC6_zps
Micko matched it up. No point having a massive lip!
151FD78A-4981-4E92-AEF1-90E043F1C700_zps
Dump tacked up. We cut down a 3 to 5 inch expander at 4 inch. The 3 to 4 in the same length was far too long.
BE819796-BCF1-4C5A-8982-A9B5F37D6409_zps
View from underneath.
3BFA8BA2-503F-4AA5-B87E-4D646D23C170_zps
50BBC131-1F45-4F97-85A1-24CEEDF5718E_zps
4 inch flexi which will go in the dump
  • Like 6
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
