Yeah, Wiggins. 5 in total. Blown cooler pipes are no longer (unless the plenum one pops). No more taking front bars off!
Thinking about painting the airbox black, cutting a hole in the top of it and using the factory airbox snorkel to feed the box too. Can't hurt!?
Silicone is good for 40 psi or so, you will be fine !
Looking GOOD brother!
I like how they ran your piping. Mine is out to the side to make room for the PS reservoir and such, but I like yours a lot. Hypertune is top-notch stuff! I am always leary of 100% solid connections to the coolers because it seems they might induce stress on the piping and turbo manifolds when the engine torques around, but they don't have anything that looks as sexy as that to be honest!
http://youtu.be/76CEWVXru3M
Have a look. They move around quite a fair bit. More than enough when all combined I'd say. :)
My fabricator is trying to talk me out of going aluminium piping, those pics just about sealed the deal for me :) looks great. I'll need to do some reading on these so called Wiggins clamps
There isn't much you need to know, they are bright purple and very racecar. Just open up your wallet and prepare for butthurt when you hear the price.
On topic, I cannot wait for this to be done. The EFR looks very at home in there that's for sure.
Adel Wiggins clamps. They're actually aviation gear but can be used in automotive applications also. They're a bit of a homo colour but they're that colour so plane guys can see them.
Make sure you're sitting down when you see the price.
What's wrong with alloy piping? Does he want to use stainless?
Yeah we use them at work (I work in an aviation environment) and they are used for everything. If they can handle bleed air straight from a turbine compressor (80+ psi and a couple of hundred degrees Celsius) then they should stop a cooler pipe coming off ;)
You should ask about having them lockwired piggaz. Just for some extra security/piece of mind.
Lock wired is a bit too much. I really can't see these blowing off with 30-35 psi considering they're rated to 150-200 psi or something. If they do then there would be another issue like a busted engine mount.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
