Stroker, vcam, efr, os box [emoji389][emoji385][emoji384][emoji387][emoji386][emoji383][emoji388]
You only live once, I say spend it all now while you can enjoy it
Lol. Hasn't all happened in a week though. Owned the car 9 years this year. Better be worth it!!!
Lol.
It ain't getting done yet. Want a back to back between "GT series and single"... For science. Lol
Excellent
Then do some track work ( 1/4 mile and laps times please)
Then do it again with the v cam ( I think drag times would show f all difference I am mainly interested in the lap time difference )
Proper back to back would be excellent
  • Like 1
I agree. V cam on the strip would make no difference whatsoever.
Just want it driving again. ARGH!
By all means Pete, once it's done, take it for a lap and see what you think. Be good to have some feedback too!
  • Like 1
Hey Paul
I am so tempted to get V can myself. But can you explain a few things for me:
1, What influences your choice of HKS step 1,2 and Pro kit?
2, how do you check valve clearance for VCam to operate? Do you have to machine the Piston recess to get valve clearance?
If I am running 272 Step 2 HKS intake cams already, does that mean piston recess would have been machined in already?
Sorry about these stupid questions as I am still learning.
Thanks
Matt
Awesome build, always love seeing the updates. Heres a pic inside my hks type r cooler just for comparison to the others for those interested.
data:image/gif;base64,R0lGODlhCAAKAIABAAAAAP///yH5BAEAAAEALAAAAAAIAAoAAAISTIBmoLy9XDqyxktfkuo05AQFADs= image.jpg
Ok so I will put up my ARC core for comparison as well :)
Just for Paulie ?
  • Like 3
Just for Paulie
Thank you all for the pics of the insides. I REALLY like that Hypertune and the ARC after seeing them. ARC will be what I order next.
Thanks.
  • Like 1
Hey Paul
Thanks
Matt
Matty,
Your 272's would be 10.2 mm of lift so they would of had to relieve the head for the lobe to spin. As for the piston, im not 100% sure when that needs to be done. My last engne was running Tomei 270 @ 10.25 mm cams and the pistons were not relieved. Ask Chris (if he is doing the work) to pop a plug out and have a look.
Step 1,2 and Pro.
Step 1 moves 30 degrees and uses a 248 @ 8.6 mm cam. You can run that with stock pistons. Dan (Silver Nur) ran this kit on his engine.
Step 2 moves 50 degrees and uses a 264 @ 8.7 mm cam. You need to have pistons relieved for this kit. Step 1 and 2 are the same price.
Pro moves 50 degrees also and uses a 264 @ 10.0 mm cam. Like step 2 you need valve relieved pistons. This kit is expensive because it comes with an ECU which you pretty much chuck in the bin (You wouldnt use it). Unfortunately you can't buy the Pro kit without the ECU.
Here is Dan's result using the Baby step one on his 2.6/2530 setup. vcam_zpsc8bc4718.jpg
Extra 50% torque (300 nm vs 450 nm) at 4000 RPM.
What setup did you use on your Nur? I can't remember now.
I chose step 2 because it was no more expensive than the step one but i'm going to try and use my current intake cam I have in the car at the moment. It cant be too hard, its just a bit of machining.
  • Like 1
Matty,
Step 1,2 and Pro.
Great results! I wonder what the increase in fuel mileage is on these setups?
Also step 2 is on sale on rhdjapan.com looks like substantial savings over the others. I did have my head machined and have valve-relieved pistons. Damnit you make me spend money!! Anyone want some brand new poncam A's?!
You just missed out on the free exhaust cam they threw in when you buy any v cam kit. Makes it even cheaper :D.
Fuel economy? Pfft. Who cares lol.
It's an American thing, some of them won't run e85 because of "bad mileage".
When are you hoping to pick your car up and do a tune?
Car is in a mates garage ATM. This weekend with any luck I'll take it out to where the exhaust is getting done and continue that. Put the front bar back on and start doing all the braided lines and fittings. Not looking forward to buying that stuff. Hate that shop!!!!
Tune? When ever it's done I suppose. Who knows when that will be.
Vcam setups work best on the street, make the engine feel bigger due to more low/midrange torque (cylinder pressure).
My 2.8 now has VCT setup (otomoto kit) and it's great, makes -5's feel like -9's, but you keep the -5's top end :)
If anyone cares: Intake 260deg 9.15mm lift, 0-20 deg sweep (NEO cam actuator), exhaust 252deg 9.7mm lift.
Piggaz' setup will be epic for a 'street car' heheh.
  • Like 3
I won't run E85 because I work in the OIL FIELD not the CORN FIELDS. :)
But honestly the only E85 station is an hour away one way. I'd have to fill drums up and truck it here to store...which I'm not 100% sure is legal without certain permits.
Dang missed the free exhaust cam :(
Oh well next time I guess. I have bigger issues worried about my stock transmission living through the current Torque and HP expectations so I should probably invest in beefing up the trans before adding more torque!
At this point, I just want to hear my car run!
  • Like 1
Thanks Paul for explanation
How does the Otomoto kit compares to the HKS VCam?
I prefer stock look of Otomoto kit.
Any opinions?
I suppose in theory the Vcam would be the superior product as it is variable (not on and off like the Nissan VCT) and swings further. I don't know if anyone has done a back to back between both systems.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
