Why couldn't they have just moved from the VL to the XR6 turbo and be happy with them.
venetians and remove front shafts. then 2 speed powerglide.
Because you are not Lebanese?
Oh I went there.
Ha ha ha. You guys.
Funny
On this topic, just a question, aren't the guys in Queensland still the record holders for the fastest GTR with 4wd, a 26, and H pattern? 7s from memory.
Don't get me wrong I love an angry Rb big cams, laggy single and a H pattern box doing 9's.
This smoothed engine bays and auto conversions not so much.
Me too. Just have no love for the 2wd auto conversion. Just get a normal skyline or falcommodore if you want to do that. Edited by XGTRX
The auto conversions are still 4WD, each to their own, I don't mind dragging to see what improvement the latest mods have made and for some shits and giggles but track is life
Come on Piggy get this thing finished already, there are tracks that need tearing up
data:image/gif;base64,R0lGODlhCAAKAIABAAAAAP///yH5BAEAAAEALAAAAAAIAAoAAAISTIBmoLy9XDqyxktfkuo05AQFADs= image.jpeg
Saw this run 10s today, vnice 34!
  • 2 months later...
Time for an update.
due to time constraints and the ever looming beer bottle, the car got taken to Grim Performance at Hornsby to get the exhaust done amongst a whole heap of other stuff.
- Exhaust completed.
- Individual EGT on manifold.
- Post turbine EGT
- Exhaust gas pressure sensor
- Pressure and temp pre and post compressor.
- Rear subframe has been out. All bushes have been replaced including diff bushes.
- Nismo GT Pro diff has been turned down to soft. Cranky unit!
- New steering race has gone in. Car slipped off a jack and busted a nob off.
To be done.
- Install and plumb fuel system with -10 Teflon braid lines.
- ECU change. Blackbox is gone, Emtron KV8 going in.
- Airbox.
- Strain gauge for sequential.
- Install V cam.
- Tune.
Ive had the Step 2 264 at 8.7 mm cam (WTF am I gonna do with a fairy penguin 8.7mm of lift) reground to something that's a bit more aggressive. Not sure of the exact grind yet but I will know soon enough. Something around 265-270 with 10.2-10.4 mm of lift.
A16A99FC-0DAF-4D17-873F-118EB0AF9872_zps
Dump pipe.
087CB4AE-9EB9-4E77-A349-4159252E74C3_zps
Mid muffler section.
33081E8A-151A-4BB5-A9BC-2BEC30E3F232_zps
Rear diff section.
675DB7AA-9981-4C63-A02C-EFC6E17DB3B8_zps
Gate merge. This photo looks funny. The merge looks very sharp but it isn't really. Must be the lighting.
6BC357F7-2A02-4F89-B59C-C8846866E33C_zps
DEE3FA94-F578-4007-BC00-40C077AE5891_zps
  • Like 7
Reason for this?
Will it chirp second?
I said jokingly "is there anything else you'd like to measure."
that was the answer. It's all got to do with measuring what the turbo is doing.
58 minutes ago, Piggaz said:
To be done.
- Airbox.
- Install V cam.
- Tune.
Getting the notification that this thread had new posts feels like a fun and rare experience now, funny as I've probably been following it for YEARS and Piggaz was a nameless face that I'd never seen in Ozziland.  Now it's a car and a person I know and there is more appreciation for the epic research, thought, development, alcohol consumed, hangovers, work, BBQs and alcohol consumed involved in getting it to this stage that it's particularly exciting seeing it get to this stage.  Very excited to see it getting near being ready to run again!
PS.  You shouldn't ask questions you may regret if they're answered :P
  • Like 2
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
